Old 02-12-2020, 11:18 AM   #1
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
Too low. Bmr+Koni yellows vs aFe Coilover.
Hard for me to say but lately I believe my car is too low. Current setup is Bmr 1" drop springs with koni yellows but looking at the aFe Control PFADT Series Featherlight Single Adjustable Drag Racing Coilover System. Anybody running anything similar? Car is mostly street driven and occasionally I get to take it to the strip, soon to have more power too.
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 02-12-2020, 11:34 AM   #2
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I run single adjustable Ridetechs. Lowered 1”. Looks about right but wouldn’t go lower or scraps splitter on my steep driveway
VR Baron is offline   Reply With Quote
Old 02-12-2020, 12:32 PM   #3
ticowarbird
BOHIC
I'm scraping everywhere especially on the highway and trailers. The car just got picked up to go up to Katech and the driver got it stuck on his battery charger.
Old 02-12-2020, 12:50 PM   #4
KillboyPowerhead
Drives: 2015 Z/22
I believe GM states that the Camaro has a 5" ground clearance from the lowest point. Maybe measure from the ground to the lowest point (front sub frame?) and see how low you actually are.
Did you time the bushings after replacing the springs (or any arms)? If not this could make the car higher or lower than the states 1" drop of the lowering springs.
KillboyPowerhead is offline   Reply With Quote
Old 02-12-2020, 12:53 PM   #5
ticowarbird
BOHIC
Did all of this and koni yellows at the same time:
BMR Suspension parts:
SP019 Lowering Springs Kit (Set of 4- 1 Inch Drop)
SB030 Sway Bar Kit F & R
BK031 Total Bushing Kit Pro Version
SFC015 Subframe Connectors
DTB004 Drive Shaft Tunnel Brace
TR003 Toe Rods Adj
TCA026 Trailing Arm
TCA028 Lower Control Arms Non-Adj
STB014 Strut Tower Bar
ELK005 Front End Link Kit
FC002 Camber Bolts
Old 02-12-2020, 07:01 PM   #6
VR Baron
With my 19” wheels I scrape going down my drive angle to street. With my street 20” wheels I have no problem other then have to watch out for tall parking lot bumpers .
Measure your height from lower wheel lip to top of fender arch. On 20” wheels front should be 25.875”, rear at 26.125”, on a 1/4 tank gas. Your 18” wheels will be 1” lower. Tolerance is about +- 3/16”
Your 18” wheels are the problem . When my friend runs his he scraped all over
Old 02-13-2020, 02:06 PM   #7
ticowarbird
BOHIC
Well I'm not changing the wheels anytime soon unless I go with a 15 in the back. Now looking at aFe vs lingenfelter for a street/drag setup.
Old 02-14-2020, 01:24 AM   #8
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
What tire are you running a 305/45r18 is stock height.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 02-16-2020, 01:26 AM   #9
ticowarbird
BOHIC
Street
Front 265/50-18 = 28.4" tall, 8w
Rear 305/45-18 = 28.8" tall, 11w
Nitto 555 front and 555r rear tires,
Strip
Front 28x6R-18LT = 28" tall, 6w
Mickey Thompson SR Radials front and
ET Street R rear tires
