Old 02-17-2020, 11:42 AM   #1
shu92870
shu92870's Avatar
Drives: 2014 Camaro SS 1LE
Bearings
Ive researched so much im still a little confused.
I have 2014 Camaro SS 1LE
Replacing the bearings because of a clunks with switching directions forward/reverse and low speed turns from stop.
Then im getting a vibration/growling/howling at 90 n louder more noticeable up to 100-105. It wasn’t doing it before i started my track days.
Fluids are good.
So going to start narrowing it down.
Here’s the question.
Part #25954415
Forum says they will fit?
Are they made for the 1LE and its abuses?
shu92870 is offline   Reply With Quote
Old 02-17-2020, 11:48 AM   #2
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
SS and 1LE have the same wheel bearings, that part number is good to go.
SSEssence is offline   Reply With Quote
Old 02-17-2020, 12:29 PM   #3
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
They are ZL1 wheel bearings. ZL1 hub part #25954415 then should be able to get diagram to get the bearing part #s.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 02-17-2020, 12:57 PM   #4
Rons1le
Rons1le's Avatar
Lots of part #s. here..
Old 02-17-2020, 06:41 PM   #5
shu92870
shu92870's Avatar
Thanks guys.
Ordered.
So F&R pads, catch can, bearings orderd.
Next weekend or weekend after ill tear into.
Hopefully that cures it.
If not its in the 1/2 shafts or diff?
Well see as I’ll probably do a rear end service at same time.
Old 02-17-2020, 08:29 PM   #6
Ammo_Don
Ammo_Don's Avatar
Drives: 15 1SS 1LE
Mine makes the same howl at highway speeds. I hope it's the hubs and not the diff.
Ammo_Don is offline   Reply With Quote
Old 02-17-2020, 11:17 PM   #7
shu92870
shu92870's Avatar
Ill keep you posted here.
Or IM me and ill get back to you with an update.
Mine clunks pretty bad forward/backwards n turning from stand still and at 90+ definitely has a howl/minor vibration associated w speed.
I find it hard to believe its normal.
I hate stealership and try to fix what i can.
