Old 02-18-2020, 09:00 AM   #1
Kevlar382
Kevlar382's Avatar
Drives: '12 ZL1; '71 RS/Z28; '99 Vette Conv
VIN number for 2SS 1LE
Can someone please help me with decoding a VIN. A friend of mine is looking at a 2013 2SS/1LT. When i went on a website to decode the VIN it didn't say anything about being a 1LE. It looks like it is a 1LE but one thing that I wonder about is it says that it doesn't have the 391 rear end. Here is the VIN #2G1FT1EWXD9233716.
I have been a Camaro5 member since I bought my 2012 ZL1 new and thought somebody here could tell me if it is a real 1LT. Thank you for your help with this.
Kevlar382 is offline   Reply With Quote
Old 02-18-2020, 09:05 AM   #2
Coz3z3
Drives: 2015 Z/28, 2015 1LE
1LT won't have the option of 1LE. Assuming you meant 1LE in your post, the VIN won't decode that as it is an RPO code. You would have to look at that sticker which is in the trunk
Coz3z3 is offline   Reply With Quote
Old 02-18-2020, 09:32 AM   #3
Kevlar382
Kevlar382's Avatar
Yes, I'm talking about the 1LE. Thank you for your help with this, it's really nice of you to take the time. I will have the dealer take a pic of the sticker in the trunk.
Old 02-19-2020, 08:18 PM   #4
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
You can check the options code sticker in the glove box or just pop the hood. White steering shaft like your ZL1 = 1LE. Regular SS’s had black steering shafts. Just an obscure thing SS1LE’s had
Old 02-20-2020, 06:54 AM   #5
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
I think you're in the wrong forum, head over to Camaro6.com
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 02-20-2020, 08:18 AM   #6
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Since the 1LE was not it's own model but rather an option there will not be a VIN identifier designating that it is a 1LE. The only way to know is to find the option code sticker that is in the trunk under the trunk liner and look for the 1LE RPO code on that sticker.
A few other things you can look for that are not typically duplicated on look alikes are:
1. White painted steering shaft in the engine bay
2. Rear axle should be marked with 3.91 gear ratio
3. Suspension components (control arms, struts, etc...) may have stickers on them that say "FE6" for the suspension code. The rear cradle I believe will also have an ID sticker on it that says "FE6" somewhere on it since the cradle bushings were different on FE6 cars.
Nick S is offline   Reply With Quote
Old 02-20-2020, 08:19 AM   #7
Nick S
Nick S's Avatar
If he is looking at a 2013 1LE that is definitely not a Camaro 6 topic. That is a 5th gen.
Old 03-08-2020, 08:06 PM   #8
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Check the steering shaft. It should be white and the steering wheel has the flat bottom.
chevy 3 is offline   Reply With Quote
Old 11-12-2020, 06:02 PM   #9
chevymahia
chevymahia's Avatar
Drives: Camaro Z28
Have you resolved your issue? I tried this VIN decoder and it worked pretty damn well. This might be very useful for your needs. If this doesn't help I would recommend you visit your local Chevrolet service.
chevymahia is offline   Reply With Quote
Old 02-27-2021, 05:22 PM   #10
El Boricua
El Boricua's Avatar
Drives: 2015 2SS 1LE Twin Turbo
Hope this helps..
El Boricua is offline   Reply With Quote
Old 02-28-2021, 11:35 AM   #11
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
Originally Posted by El Boricua View Post
Hope this helps..
I know you're just trying to be helpful, but that info from ZL1 reg is wrong and has been forever.
One cannot identify a 1LE optioned SS from just looking at the VIN. The 1LE and non-1LE cars use the same letter in the VIN for the engine, so no way to tell by just looking at VIN. You need to have a look at the RPO code sticker in the trunk.
You could use the VIN to get a dealer/GM build sheet and then you'd see the options list like 1LE, etc.
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 03-01-2021, 12:23 AM   #12
SSJ2
SSJ2's Avatar
Drives: 2010 2SS CAMARO
I can give you complete vin RPO code breakdown if needed.
BBK Long tube headers, Hi flo cats, straight pipe muffler delete with j-pipes. K+N CAI, Soler Performance Ported Throttle Body, Soler Performance Throttle Controller, Phantom Grill, MGW flatstick shifter. 3.91 Gears, Ported Rod Mod Intake, ZTA Spoiler, Rohana RC22 20x10 20x11.
SSJ2 is offline   Reply With Quote
