Old 02-18-2020, 11:17 PM   #1
shu92870
shu92870's Avatar
Drives: 2014 Camaro SS 1LE
LS1 LS3 LS6 Clutch Kits Same???
Do all these engines use the same clutch kits/flywheels?
Different pilot bearings?
shu92870 is offline   Reply With Quote
Old 02-19-2020, 10:06 AM   #2
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
same basic setup. Are you looking for a stock replacement or aftermarket? Or just curious.
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 02-19-2020, 12:01 PM   #3
shu92870
shu92870's Avatar
Something a little better then stock.
The 2014 Camaro SS 1LE is mostly relegated to weekend warrior track status.
Headers n tune coming. Clutch is about gone.
Old 02-19-2020, 01:16 PM   #4
PapaKlutch
PapaKlutch's Avatar
Stock Clutch kit will hold cold air intake, headers, even new cam horsepower. If the old unit is dying tho, a new clutch and associated parts, etc. are expensive. So do it once....meaning put the clutch in that will support your future power goals.
McLeod, Centerforce, and Monster have popular units. Several add-on parts are done by most while it's all torn apart. A new slave, Monster billet support, stainless clutch line, Speed-bleed line, spilt brake/clutch reservoirs, DOT 4, etc.
Old 02-19-2020, 08:41 PM   #5
shu92870
shu92870's Avatar
How about a Spec Stage 2+ for LS1/LS6?
Guy says will fit LS3/LS7.
Comes with billet steel flywheel but that ill need ARP bolts, throw out bearing n associated slave etc.
Just curious if its all the same.
Ill try spec tomorrow jist thought id ask
Old 02-20-2020, 12:23 PM   #6
PapaKlutch
PapaKlutch's Avatar
Ya, ARP or GM bolt kit, etc., etc.
No personal experience with SPEC. I've heard good and bad.
Old 02-20-2020, 01:43 PM   #7
Coz3z3
Drives: 2015 Z/28, 2015 1LE
I was recommended the LS9 clutch kit. They say it holds up to 7000 or 7500rpms but yet feels like the stock clutch. If you are looking for just a little over stock. The Flywheel bolt pattern is different. But Katech offers a kit for the whole thing.
Coz3z3 is offline   Reply With Quote
Old 02-22-2020, 02:03 AM   #8
shu92870
shu92870's Avatar
Called SPEC today.
Seems i can use the SP093H its a SPEC Stage 2+.
Only difference is the clutch is 1/4 smaller - 11 3/4" versus 12"
Shouldn't make a noticeable difference.
I couldn't pass up.
With flywheel under $400 delivered.
Old 02-22-2020, 02:14 AM   #9
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I hate to say this but you get what you pay for most other clutch manufacturers for our cars is around a grand an up. Good luck an keep us posted please.
Orange Krush II
Old 02-22-2020, 02:25 AM   #10
shu92870
shu92870's Avatar
IT WAS almost a $1000.
My buddy bought for his corvette.
Then upped his power and went to a twin disc instead.
There is ton reviews either way on EVERY manufacturer.
Ill try and report back either way.
Im not a fan of resurfacing the flywheel. So really a no brainer.
Old 02-22-2020, 07:56 AM   #11
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
So you bought a used one now that makes more sense!! I have a monster I need to get installed.
Orange Krush II
Old 02-22-2020, 12:53 PM   #12
shu92870
shu92870's Avatar
Actually not used.
Never installed.
He tore apart then he decided to add power n then added twin disc setup.
