Old 02-19-2020, 10:48 AM   #1
bpc
Drives: 2015 Black ZL1
My Complete modes
2015 ZL1 Auto trans
I went all out and completed the Mods I wished for.... see blow
1. Full Ported heads by Texas speed
2. Full tilt blower package and snout porting by Jokerz
3. NW 102 throttle body
4. Stage 3 blower cam from Texas speed
5. 5 inch intake
6. ID 1050 injectors
7. Afco heat exchanger
8. 235 upper and 15 inch lower should make about 15lp boost
9. Meth injection duo nozzle
10 2 inch heads with custom catless 3 inch exhaust and x-pipe
11. 3200 stall converter
12. new high flow fuel pumps for the new demand
13. 2 gallon coolant expansion tank
This is going to be dyno and tuned at the end of the week on 94 oct fuel which we have here in Canada. I'm hoping to reach the 800 whp range what will you guy's predict.....Thanks
bpc is offline   Reply With Quote
Old 02-19-2020, 12:54 PM   #2
cray z1
Drives: 2014 Camaro ZL1 Red Hot Red
I'm also in Canada and doing almost the exact same second round of modifications as you right now, except I was going with 2.55 upper and 9.55 lower =16-17 lbs. I wasn't planning on changing the stock fuel pump with two meth nozzles and BAP. (No E85 around here only 94 octane pump gas). Where are you getting it tuned?
cray z1 is offline   Reply With Quote
Old 02-19-2020, 01:03 PM   #3
bpc
The shop is located in Stoney creek Ontario BMS Tuning. Yes No E85
Old 02-19-2020, 03:51 PM   #4
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
My guess is 750-770 through your A6. 800 with an M6, but not an auto in my opinion. I hope you prove me wrong, though!
Also, I'd love to see the frame and pulley system modifications to make that 15" lower fit in there...
In all seriousness though, I'm guessing it's maybe an 8.66 lower?
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // JMS // Elite Ultra CC // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, etc., etc.
RobZL1 is offline   Reply With Quote
Old 02-19-2020, 05:09 PM   #5
champwynn
Drives: 2012 Camaro 2SS 2002 Camaro SS
Did you have difficulty installing the "full tilt" since it requires additional fabrication?
2002 Camaro SS mods (a lot)
2012 Camaro SS mods (a little)
champwynn is offline   Reply With Quote
Old 02-19-2020, 08:59 PM   #6
HDRDTD
I'm guess perhaps the OP meant a 10.5 lower?
Old 02-19-2020, 10:33 PM   #7
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Heck, I hope not. That would put him at 10.5/2.35 = 4.47 ratio.
Very curious what the actual pulley combo is. I just guessed 8.66 because it seemed reasonable with the 2.35 upper.
Old 02-19-2020, 11:07 PM   #8
FasNuf
FasNuf's Avatar
Did he mean 15%
FasNuf is offline   Reply With Quote
Old 02-20-2020, 01:06 AM   #9
GODZL1A
GODZL1A's Avatar
Drives: 2015 ZL1
Skip #11 all else is fine 👍
GODZL1A is offline   Reply With Quote
Old 02-20-2020, 04:23 AM   #10
Ajax2112
Drives: ZL1
Originally Posted by GODZL1A View Post
Skip #11 all else is fine ��
Skip the converter? The cam requires it as the loop of the cam would cause surging without it.
Ajax2112 is offline   Reply With Quote
Old 02-20-2020, 04:36 AM   #11
rmcbee
rmcbee's Avatar
Drives: 2013 ZL1
All that for only 7 and change?
rmcbee is offline   Reply With Quote
Old 02-20-2020, 08:19 AM   #12
bpc
As soon as I get the correct build sheet I will update you guy's. I believe the original 8.66 was the stock lower
pulley, it was removed for a 10% now it's a 15 inch the fit was spot on not sure on the percentage size. My stock converter was customized to 3200 stall.
Old 02-20-2020, 09:53 AM   #13
bpc
My old cam was a stag 1 blower cam from Texas speed stock converter was good. With the old setup no head porting or blower porting, stock throttle body, cold air induction air intake, Meth and pulleys approx. 14lb of boost and 2 inch headers I ran a 10.83 at 129.4 this was with the stock converter and 20 inch stock rims using SS drag radials
Old 02-21-2020, 05:03 AM   #14
12oclockshadow
Drives: 2012 ZL1 M6
Looks like a beast of a build. Looking forward to some time slips ��
FBO. Cammed. Flex fuel.801whp/741wtq on e85
12oclockshadow is offline   Reply With Quote
