![]() Drives: 2010 Camaro SS Join Date: Jan 2018
Twin Turbo kit
Torn between the AGP and Huron speed kit. Which one should I go with? Stock LS3 with FBO and big cam. Looking to make around 800 to the wheels on E85.
TIA |
![]() ![]() Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
I have an AGP kit, but I hear that the Huron kit is nice as well. You could easily reach your goal with either one. I would probably go with the one that offered the best price/to parts ratios. Just make sure you are comparing apples to apples with your turbo combination. (i.e. journal bearings to journal bearings, etc.).
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Go search/look/read all of the builds from those two brands. That will help get you started. Different people will have different experiences. Also read up on a thread on another board titled the true cost of turbocharging. Be honest with what your goals are and spend the money once upfront. Call both vendors and talk with them to get a feel how they will mesh with your personality. Is either coming out with major upgrades in the next 6-12 months where it might be smarter to wait (and read a crap ton more)? Is either one closer. If you are going to use a shop and tuner - what are their experiences? Just a bit to get started....
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
![]() ![]() ![]() Drives: All things Turbocharged Join Date: Dec 2010
Our TT kit has a lot more invested into making it an OE quality, long term reliable system. One of the key components is our cast iron turbo adaptors. Welded together tubes and flanges pre-turbo are known for warping and cracking at the welds. Wastegate tubes have been known to brake clean off welded units and leave your wastegate tumbling down the street behind you (AGP customer now). Our's being cast to shape from high silicone moly, have no stresses from rolling out or bending. Stress releaving when heated is the casue of warping and cracking. High silicone moly tolerates heat and insolates it much better. Also by casting the adapters we were able to have them oval out between the underside of the car and turbo, tucking the turbos up so they don't hang below the frame. A solid inch higher off the ground.
Also we don't pay our customers for positive reviews. It's pretty scummy when you as a potential customer are doing research, and what you think are genuine reviews are actually deceptive advertising. |
![]() ![]() Drives: T Join Date: Mar 2015
Huron twins, go big or go home.
#6 |
Thanks for the advice AGP. The only reason I was considering Huron was because 1). My engine builder suggested them from previous use and 2). The option to go oil less turbo’s and get rid of the scavenge pump and lines. Not really sure which turbo’s to run.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2009 ZR1 Join Date: May 2010
I heart AGP and I don't have a camaro anymore. I had three different sets of AGP turbos on my car as the build evolved ending with 6565s and a 427 LSX. If they made a turbo kit for a ZR1, guess what I would be running?
Kevin (AGP's owner) was always responsive and helpful when I needed it. He also would not sell me anything I didn't need when my imagination went wild. |
#8 | |
#9 | |
Since you have a big cam and know how to drive turbo cars, just get the 57/57 .82. They are capable of 1000whp so 800whp will be cake and will pull to redline the way you are use to. BTW I'm doing a turbo K24 swap into my old Jeep. LOL. Last edited by AGP Turbo; 02-21-2020 at 12:15 AM. |
#10 | |
1100whp is pretty easy and doesn't brake too much stuff all the time. I highly recommend this and the cars are insanely enjoyable there. Can be done with smaller 6262 turbos that spool quick and crank out a huge power band 1050+wtq. Light weight LSA block or 6.0l truck block will do and your stock 4bolt heads will to. Good twin disc clutch, ZL1 rear, big fuel system and go have fun. To get well past 1200whp and have some reliability will require a printing press for Benjamins. Maybe head examined This is like 2x in cost and questionable usability under 160mph. For a half mile or mile car you can really use all of this power. Or if it's a drag car racing on a well prepped track, you can use it all. But the car turns into a lot less fun to drive other than racing. LSX engine only, even expensive transmissions and rear ends will be maintanance items. Lose all the weight out of the car you can, cause that's really what's killing drivetain parts.
#11 | |
#12 | |
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
#14 | |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
