Old 02-21-2020, 01:39 PM   #1
co14camaro
Drives: 2014 Camaro
Edelbrock E-Force Kit on Gen 5 LFX?
Out of curiosity has anyone attempted to install Edelbrock's E-Force roots blower kit onto a Gen 5 LFX? From what I can see everything should bolt up but the tuning is the question. Or has anyone reached out to them to see if they would offer a kit for Gen 5 guys?
My last project car had a roots blown V6 and I absolutely loved it!
co14camaro is offline   Reply With Quote
Old 02-23-2020, 10:07 AM   #2
Pearlj10
Drives: 2011 Camaro 2LT
I contacted Edelbrock to ask if they had any plans to release a 5th Gen SC and the response was “no intention to do so at this time.” Given how old our 5th gens are now, I don’t see them doing it. Curious if it’s just a tune issue between the LFX and current V6.
Pearlj10 is offline   Reply With Quote
Old 02-23-2020, 04:28 PM   #3
bill522
Drives: 2014 LS Camaro
Edelbrock E Kit
Proven S/C kit available from Overkill for 5th Gen V6 Camaro (centrifugal V3 S/C).
I have been running it for 5 years ( 2014 LFX) and no problems.
Price is comparable to Edelbrock E -Force Kit.
bill522 is offline   Reply With Quote
Old 02-24-2020, 06:39 AM   #4
co14camaro
Drives: 2014 Camaro
I personally prefer a roots blower to a centrifugal.
Old 02-25-2020, 09:16 AM   #5
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
I believe the differences between the LGX and LFX would make use of the kit improbable at best.
DSX_Camaro is offline   Reply With Quote
Old 03-06-2020, 06:38 AM   #6
co14camaro
Drives: 2014 Camaro
Your right! Just did some research and GM totally changed the intake side of the heads on the LGX. Bastards! Too bad Edelbrock didn't make a kit with a swappable adapter plate so it couuld work on the various V6 versions. Would have massively expanded the product catalog with minimal changes to the overall kit. Bad planning on their part!
Old 03-10-2020, 03:15 PM   #7
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot A6
That would have made too much sense.
Looking at their numbers, it doesn't make much power for the money. I too prefer a root based inductions, but the centrifugal from Overkill is by far more power for the money.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
15RS2NV is offline   Reply With Quote
Old 03-10-2020, 03:55 PM   #8
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
https://www.ebay.com/itm/NEW-GM-EATO...oAAOSww5Zdllud
I came across a thread on LS1 tech a while back where a guy was using these blowers with a modified intake manifold. Might be a solution for you OP without breaking the bank.
GJDM
LsxDoctor is offline   Reply With Quote
Old 03-10-2020, 08:05 PM   #9
DSX_Camaro
DSX_Camaro's Avatar
Just looking at it, I'd wager it's too tall. The V6 sits slightly higher than the V8 if memory serves.
Old 12-05-2020, 01:15 PM   #10
Whoomba
Drives: 2024 Camaro 2SS CE Convertible
Do you have before and after dyno numbers?
Whoomba is offline   Reply With Quote
Old 12-05-2020, 08:51 PM   #11
Pearlj10
My 2011 LLT with 40k miles jumped from 269 rwhp with headers and a few other bolt ones to 412 rwhp with the overkill sc and and a little methanol and a boost a pump to keep the high pressure fuel pump from starving at full boost. 0-60 in 4.4. Haven’t been able to do a 1/4 thanks to Covid.
Old 12-14-2020, 09:52 PM   #12
crc91
crc91's Avatar
Drives: '14 1LS
My upgraded stage 2 overkill kit is for sale if anyone is interested. The roots blower on the v6 does sit very tall, and for what it’s worth the Centri makes great power and doesn’t require custom fitment, and a copo hood( which does look awesome) roots style blower tend to make a little more torque but adding some gears to a centri equipped car would more then make up for the difference and you still won’t get that heat soak on top the motor
Patiently waiting for my 2023 SS 1LE
crc91 is offline   Reply With Quote
Old 12-27-2020, 05:30 PM   #13
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Would my 2015 Buick have the LFX engine?
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
