Old 02-23-2020, 06:02 PM   #1
Dlsbobby
Dlsbobby's Avatar
Drives: 2010 Camaro ss M6
AGP Turbo ?
I'm thinking these turbos, 62/62 Journal bearing turbos - .82 a/r 1100whp is probably too big for a stock cubes heads and cam LS3.
Do you guys agree? I don't want huge turbo lag. In the future I want to go 441ci then they might not be too big. What do you think?
Thanks for your help.
Bob.
Dlsbobby is offline   Reply With Quote
Old 02-24-2020, 09:41 AM   #2
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Call them up and talk to Kevin or send him a PM on here. Let him know your plans and he'll set you up with the right setup. His customer service is top notch.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 02-24-2020, 09:55 AM   #3
mrimpala02
Drives: Black 2SS RS w/White Stripes
Bob.
I have 62/65 BB turbos on stock cube LS3 M6 car and it's not bad at all. I had 3.91's which I felt was too much gear and didn't load the turbos enough so I ended up switching to 3.27's. Now it feels perfect for street driving and roll racing. You do have to change up you driving habits a bit, but nothing major. Either way brake boosting helps cure all perceived lag. I say perceived because everyone has an opinion on how much lag is too much or no lag. I too plan to my cubes when I decide to build my engine.
You may want to base your turbos on your timeline and mileage you plan on before building you 441. If you plan on the engine upgrade in a year or two I would opt for the bigger turbos. If the build is further out you may want to go a tad smaller and by the time you decide to build your engine in 2 or 3 years you may be wanting to refresh your turbos anyway and then you just upgrade.
Best advice though is contact Kevin!
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 02-24-2020, 10:24 PM   #4
Dlsbobby
Dlsbobby's Avatar
Thank you both for your help.
