Old 02-26-2020, 10:53 AM   #1
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
Chute
Wanted to see which chute you guys are using and where the best deal might be had?
graf101 is offline   Reply With Quote
Old 02-26-2020, 01:34 PM   #2
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
How are you gonna use a chute if your car never leaves the shop
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 02-26-2020, 02:17 PM   #3
graf101
Trouble_SM
graf101's Avatar
Mainly just want it for car shows like you.
Old 02-26-2020, 02:46 PM   #4
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I use the midwest chassis mount. Stroud 430 pilot chute. Air launcher is in my future though. It's impossible to pack by yourself lol
ttshovel is offline   Reply With Quote
Old 02-26-2020, 03:53 PM   #5
SynergyGreenSS
Drives: 2011 2SS
Jokes on you, I can’t go to shows if the car is always broken
2011 SS L99
Old 02-28-2020, 10:45 AM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
Motion Raceworks and Racecraft makes great kits for our cars. Not crazy high either.
62nalide is offline   Reply With Quote
Old 02-28-2020, 02:42 PM   #7
bct10985
Drives: 2010 2SS LS3, 2013 duramax
The hole u drill for the midwest chassis chute mount is hidden behind the license plate. The pic ive seen of the motion its not.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 02-28-2020, 02:45 PM   #8
bct10985
Heres mine.
Old 02-28-2020, 04:11 PM   #9
graf101
Trouble_SM
graf101's Avatar
Thanks guys!
