Old 02-27-2020, 05:42 PM   #1
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
12-15 2 piece rotor options?
I've done some research, but not finding a clear answer. Is there any other option besides OE AC Delco 2 piece rotors? OE part # 177-1146 and 177-1145.
I saw StopTech 126-62119CSR is a 2 piece rotor and says it will fit ZL1? Image added below.
Astatenate is offline   Reply With Quote
Old 02-27-2020, 09:56 PM   #2
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I have RacingBrake 2-pc front and rear on mine.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 02-27-2020, 11:20 PM   #3
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
That Stoptech # is coming up cryo treated one piece for the rear.
Cost vs quality, the OE 2 piece rotor is hard to beat. They are Brembo rotors and are high quality. If you are looking for looks (drilled/slotted) there are very few 2 piece options.
Here are other options but big money:
https://knsbrakes.com/c/car-series/1...-+Single+Rotor
https://knsbrakes.com/c/car-series/1...+Rotors+-+PAIR
You can also run a C7 Corvette ZO6 (non CCB) rotor ring from DBA. You take the OE ZL1 hat and use it on the DBA ring.
The Gen 6 SS 1LE and Gen 5 ZL1 share the same Brembo set up EXCEPT the hat offset is different. That is why we must reuse the OE Gen5 ZL1 hat.
https://www.camaro6.com/forums/showthread.php?t=492428
Ken @ knsbrakes.com can hook you up.
https://knsbrakes.com/c/car-series/4...-+Single+Rotor
Here's my DBA's for my '14 1LE with the Brembo 6 pistons
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 02-27-2020, 11:43 PM   #4
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
You’re always on here helping me huh? Thanks man! Those RB brakes are like $2300? I’ll stick with OE. I suppose Brembo will suffice. Lol
Attachment 1021520
Attachment 1021521
Hmm I’ll stick with OE I guess. They seem pretty good. Just wasn’t sure if that was a good bang for my buck.
Old 02-28-2020, 12:10 AM   #5
cdb95z28
cdb95z28's Avatar
Yes, the Brembos are very good. I've tracked with them and they handle that stress very well. If you are patient, the price varies on amazon and rockauto.com. Put them in your amazon list and get the Honey app to watch the price.
Old 02-28-2020, 12:43 PM   #6
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
I actually use the honey app! And got both rotors for $579 and pads for $45! After tax everything rotors + pads was $680! Thanks guys!
Old 02-29-2020, 06:49 AM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Go to Rock Auto they have OEM rotors and the tires then they have actual Brembro rotors and they are significantly cheaper.
https://www.rockauto.com/en/catalog/...hub,rotor,1896
Orange Krush II
Old 02-29-2020, 09:20 AM   #8
Steven Vaccaro
Steven Vaccaro's Avatar
Drives: 2014 Silver ZL1
Stupid question, can we do anything to treat the rust on the center section?
Steven Vaccaro is offline   Reply With Quote
Old 03-02-2020, 10:00 AM   #9
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
Wish I woulda saw that! I just ended up getting online. I paid $579.95 w/ free shipping but had to pay taxes. So it was like $630 ish. Rock auto had them for $585 after shipping. But I don’t think sales tax. if they have sales tax too, then I made out about the same if not a few bucks cheaper.
I hear there’s a black coating they can apply. But you have to do that from the get go. Steel wool / wire brush will take it off and you can tape off brakes and spray the center parts.
Old 03-02-2020, 08:59 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Wonder if Ceracoat would hold up to the for the hats???
Orange Krush II
Old 03-03-2020, 02:27 PM   #11
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
From my brief internet searches, seems like it would. I clean mine regularly so I may invest in some! Or use a high heat wax spray I have laying down. My car doesn't really see rain. Just water hose and foam cannon LOL
Old 12-06-2020, 07:04 PM   #12
cdb95z28
cdb95z28's Avatar
New option, Brembo (non-GM sourced) 2 piece
I found this on Rockauto.com.
Brembo now has their own aftermarket 2 piece ZL1 rotors. They look identical to their same 2 piece rotors they supply GM with.
I have purchased them and they have the same vent design, vane count and the same hat and fasteners The finish looks the same.
BREMBO #09A66513 Left
BREMBO #09A66523 Right
Prices sometimes change on RockAuto, but they are currently about $170 each, compared to the GM sourced Brembos at about $290
It is possible that the cast iron is different, but everything else looks to be the same. As I mentioned, I have purchased a pair . I track my '14 1LE with the 6 piston front brakes and have no reservations with using these on track. They very well could be 100% identical but without the GM price surcharge.
https://www.brembostoreusa.com/produ...rotor/09A66513
https://www.brembostoreusa.com/produ...rotor/09A66523
Old 12-12-2023, 09:38 PM   #13
cdb95z28
cdb95z28's Avatar
The DBA rotor rings are on sale at CSP
$293 each
Old 02-12-2024, 10:45 PM   #14
Fanch1LE
Fanch1LE's Avatar
Drives: 2015 1SS 1LE
Thanks for the heads up. Just grabbed some for $302. Still quite a bit less than most places list them.
Fanch1LE is offline   Reply With Quote
