02-27-2020, 04:51 PM | #1 |
Drives: 2011 Camaro SS Join Date: Jul 2017
Front suspension mods
Ok so my 2011 SS is a street car but not my DD. I have done the usual to upgrade the rear suspension but what about the front end? My previous Camaro was a 17 ZL1 and that car handled amazing. I don't want to get my 5th gen to handle like a 6th gen ZL1 but maybe as good as a 5th gen 1LE. My current suspension mods are BMR 1.4 lowering springs. Pedders lowered front struts and rear shocks. BMR non adjustable toe rods and trailing arms, Poly urethane cradle bushings , Hendrix offset diff bushings. What can or should I do for the front end? I've been looking at sway bar kits lately. I'm looking to get rid of the factory front end vagueness and understeer. Thanks
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
02-27-2020, 07:13 PM | #2 |
Camber plates if you didn’t install them yet!
Car mods: never enough!
02-27-2020, 07:45 PM | #3 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Camber plates or SPC eccentric camber bolts, caster kit from Detroit Speed, radius arm inserts, steering rack bushing, and sway bars are about all else you can do in the front. It really doesnt need much. What are your alignment specs?
More to come. |
02-27-2020, 08:23 PM | #4 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Try an find a 1LE front bar and 35mm bar from DSE, look into Hammando’s front end mod using 6th Gen front control arms with BMR spherical bearings. Don said it made the front end much better.
https://www.camaro5.com/forums/showt...85577&page=172 It’s a bit of a read but lots of good information.
Orange Krush II
03-06-2020, 06:00 AM | #5 |
Lots to do!
Hello,
There is allot you can do. Here check out my build under the suspension. I am able to pull1.2 G's around street corners. https://www.camaro5.com/forums/showt...=571243&page=2 |
03-06-2020, 10:37 AM | #6 |
Cool!!
