Old 02-29-2020, 12:16 AM   #1
Leon1le
Leon1le's Avatar
Drives: Chevy Camaro SS 1Le
In help for part number for 2013 SS 1le axle nuts
My car was making a thump/ click sound when accelerating from a dead stop. Was looking around and did some research and came to the conclusion that it was the washer on the axle. Not sure how but it was. The washer was there and just replaced it P/N 11611965, greased the spline.No more thumps. The axle nut I order didn’t fit, must of got the regular ss axle nuts. Any one have the part number for 1le axles ?
Leon1le is offline   Reply With Quote
Old 02-29-2020, 07:54 AM   #2
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I don't have a part number but our 1LE uses ZL1 axles? So look that up and you should be good.
Sent from my SM-T837V using Tapatalk
Firefighter is offline   Reply With Quote
Old 02-29-2020, 02:04 PM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
1LE’s don’t have ZL1 axles, inner stub are different but outer might be the same they both have the same wheel hub bearing.
Orange Krush II
Old 02-29-2020, 02:55 PM   #4
Firefighter
I thought it was hubs and axles. Guess I'm wrong.
Sent from my SM-G973U using Tapatalk
Old 03-01-2020, 12:09 AM   #5
Leon1le
Leon1le's Avatar
Thanks y’all ,
Found out REGULAR ss and ss 1le have different part numbers for axle nuts.
REGULAR SS PN/ 11611687
SS 1le PN/ 11611234
Hope this helps
Old 03-01-2020, 06:58 AM   #6
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
Originally Posted by Leon1le View Post
Thanks y’all ,
SS 1le PN/ 11611234
Hope this helps
I have a 2014 RS 2LT and part number 11611687 also fits this vehicle. Just looked at my receipt, paid $6.44 for each. Torque on those babies was 199 foot pounds, eat your Cheerios!
Deputy347k9 is offline   Reply With Quote
Old 03-01-2020, 08:26 AM   #7
Firefighter
Thanks y’all ,
SS 1le PN/ 11611234
Hope this helps
Good to know, glad you figured it out.
