Old 03-02-2020, 05:24 AM   #1
milo8604
SSonBayou
milo8604's Avatar
Drives: GreySS M6 SS
AGP or Fore Dual Pump system
Will be adding boost to my sbe ls3 soon. Trying to decide on which fuel system to choose. The AGP system is alot less expensive. I can almost get there triple pump setup for the price of Fore L2 dual pump. What are the differences and pros cons of both?
milo8604 is offline   Reply With Quote
Old 03-02-2020, 06:25 AM   #2
eLeSthree
Drives: 2011 Camaro SS 6sp
do either come with PTFE hose/fittings?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 03-02-2020, 07:46 AM   #3
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
what is your end goal for HP?
Greenhornet2 is offline   Reply With Quote
Old 03-02-2020, 07:55 AM   #4
milo8604
SSonBayou
milo8604's Avatar
Yes both come with -8 feed. The Fore kit comes with -8 feed and return with -10 feed option. I believe Agp uses factory feed as return
Old 03-02-2020, 08:12 AM   #5
eLeSthree
Go back to their websites and look for the word PTFE. I didnt see it.
1158whp 1017wtq.
630whp 658wtq
Old 03-02-2020, 01:12 PM   #6
mrimpala02
Drives: Black 2SS RS w/White Stripes
I believe the AGP kit comes with the FlexLP or equivalent hose that is mentioned on Fore's site.
https://www.foreinnovations.com/category_s/306.htm
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 03-02-2020, 05:44 PM   #7
AGP Turbo
Drives: All things Turbocharged
The components in our system are all rated for Ethanal use. We just save a bunch of costs simplifying to less lines and fittings by making our own inhouse fittings that allow you to use the factory line as your return line. All double o-ring seal just like OEM equipment. Use simple off the shelf OEM automotive grade sealed 40A relays for each pump. Ours installs very clean and stealth looking with Camaro5 specific brackets and our lines are black nylon braiding over top of a rubber layer that is over top of the braided stainless layer. Looks good, flexible, doesn't scratch or abrade, and is alcohol rated. We've tested the living heck out of this system on some of the most powerful Camaro5's all around the world for years and are very satisfied it's totally reliable.
AGP Turbo is offline   Reply With Quote
Old 03-04-2020, 05:39 PM   #8
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Been running AGP's twin pump setup for awhile now, E85 as well, and I have zero issues, i.e. no smell of gas.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 03-05-2020, 08:01 AM   #9
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
How about Squash
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.12@156
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 03-05-2020, 11:54 PM   #10
Big Biscuits
Big Biscuits's Avatar
Drives: 2010 1SS LS3
I like my fore L2 twin system but if I were to do it again I would go with a bucket style system like squash. I have zero issues with mine, just having fuel in the bucket makes me feel better. Or wait to see what dsx tuning comes up with on their triple. I would do the fore fcm3 with the dsx pump in a heartbeat. Fore wiring harness and relay module is tits.
2010 CGM 1SS
408/4L80E/ZL1
Vortech V-13 94C
Big Biscuits is offline   Reply With Quote
Old 04-28-2020, 01:06 AM   #11
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Could you use the Holley hydromat with that system?
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 04-28-2020, 10:48 PM   #12
Juiced1
Drives: 2012 2SS CAMARO 45th
Hit us up and we can get you a good deal on a Fore setup.
Juiced1 is offline   Reply With Quote
