Old 03-02-2020, 10:59 AM   #1
RedSky19
Drives: 2014 Camaro SS 1LE
2014 Camaro SS 1le Cam question
Hello everyone,
I am looking to cam my car. I ordered the BTR stage 3 N/A cam, but am now second guessing how that cam stands against the:
Night fury, TSP stage 3 cam, and the SS3 cam.
The car is a weekend car with low miles, looking to make power and quicker et’s and going forced induction in a year or so (supercharger).
Thank you in advance.
RedSky19 is offline   Reply With Quote
Old 03-02-2020, 02:42 PM   #2
06blownSS
06blownSS's Avatar
Drives: 2010 Camaro SS
I installed the Stage 3 BTR cam last summer and I do not regret it one bit.
I can't compare to other cams, but if your planning on supercharging the BTR is a good cam. Was recommended to me by multiple shops too.
Link to my build: https://www.camaro5.com/forums/showthread.php?t=557311
good luck
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
06blownSS is offline   Reply With Quote
Old 03-02-2020, 02:48 PM   #3
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
A friend I autocross with has it and likes the power. Makes only 15 more hp then my custom stage one but makes power a few hundred rpm higher. Bad thing is low rpm bog and drive ability in parking lots and such.
VR Baron is offline   Reply With Quote
Old 03-02-2020, 06:20 PM   #4
RedSky19
Awesome, thank you both for that information!
Old 03-03-2020, 06:34 PM   #5
Kleinarms
Drives: 2013 2SS 6 spdBorla attack, CAI,LTH
I have similar ?'s. slightly different set up.
standard trans, plan on staying NA.
mods; CAI, long tubes, offroad pipes, borla attack mufflers, and dyno tune @ 425RWHP
Would like a daily drivable gain of 75hp. Just looking for suggestions. also what else to change with out driving cost up Too much. ideas welcome
Thanks.
Also looking for best compound for removing swirls, but that's another post!
Kleinarms is offline   Reply With Quote
Old 03-03-2020, 06:43 PM   #6
Russell James
Russell James's Avatar
As with any cam question... call a cam expert. Kip at Cam Motion or Brian Tooley or GPI or TSP or JRE.... they know their stuff.
Tell the cam grinder exactly what you want, let them custom spec one using the best core material. A shelf cam is just that, compromises to fit a wide variety. Pay a nit more to get a customized recommendation perfected for your needs on a better core.
Old 03-03-2020, 08:44 PM   #7
RupertPupkin
Drives: 2014 Camaro SS 1Le
What kind of supercharger? That will affect the type of cam you get also. A lot of the cams you mentioned are good. I have the tick polluter stage 3 cam, more comparable to the BTR stg 4 cam. Drives smooth as buttaaaa...
RupertPupkin is offline   Reply With Quote
Old 03-04-2020, 12:53 AM   #8
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Originally Posted by RedSky19 View Post
Hello everyone,
TSP is good stuff. Made 519rwhp cam only with their old stage 3.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 04-01-2020, 11:57 PM   #9
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Uh...
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 04-02-2020, 01:41 PM   #10
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Originally Posted by pnwdan View Post
Uh...
He has a proper full bolt on set up with a short runner intake.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 04-02-2020, 01:47 PM   #11
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Said cam only so
2014 2SS/RS LS3/M6
Old 04-02-2020, 02:34 PM   #12
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
BTR is good stuff. I'd stick with it. As far as for FI down the road it won't be the optimal cam, but it will still make plenty of power i wouldn't worry about it. When you tear it down again would be the time to get a custom grind cam depending on the rest of the build.
Greenhornet2 is offline   Reply With Quote
Old 04-02-2020, 03:05 PM   #13
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Do the cam and supercharger at the same time ,and pick a specific blower cam and valve train with a proper tune . Do it right the first time and you will have no regrets in the end .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 04-03-2020, 09:33 AM   #14
IWANTA(ss)
IWANTA(ss)'s Avatar
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14
If I had to do it again I’d call GPI and discuss goals and budget b4 bought anything
02 Stepside Silverado
05 ZX-10
13 1LE
14 Nightrod Special
IWANTA(ss) is offline   Reply With Quote
