03-12-2020, 02:14 PM | #1 |
LEXi is Sassy and Classy
Drives: 2012 Camaro 2LT RS Boston Acoustic Join Date: Mar 2014
Changing Spark Plugs
Could someone please redirect me to instructions on replacing spark plugs? Thanks.
03-12-2020, 02:20 PM | #2 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
10mm socket on the coil pack, unplug the coil pack. Pull the coil pack off.
Then use a 5/8 spark plug socket on an extension and take the spark plug out. Repeat for all 6 plugs. I like to put a little dielectric grease on the tip of the coil pack when seating it back on thew new plugs. Super easy on the LFX
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
03-13-2020, 02:53 AM | #3 |
The LLT, you will need to rotate the passenger side two rear coil packs to clear the
intake manifold to remove them from the plug. Have to remove the Purge Solenoid, and hoses as well for clearance. I was going to do mine, but a bolt is stripped in the valve cover, and won't come out. Someone really honked them on good. All but the one will come out... |
03-13-2020, 09:05 AM | #4 |
Forgot to post this, but this guy has a good write-up on it: https://paulstravelpictures.com/GM-C...ide/index.html
03-16-2020, 03:28 PM | #5 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
The only thing i would add as an old car guy would be to hit each plug well with either a little compressed air or suction from a shop vac before plug removal. Keeping anything from dropping in the plug hole is a good idea.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
03-17-2020, 05:42 AM | #6 | |
Only if your plug valley seals are leaking... There should be nothing to fall in... |
