Old 03-12-2020, 08:01 PM   #1
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Upgrading from stock 2010 SS stereo help
Hey all,
I have a 2010 SS 2SS with the stock radio setup. My car doesn't have a back-up camera and I would really love to upgrade to a touch-screen and also get a back-up camera put in. What am I looking at for parts/install? I'm hoping around $1k, but unsure.
Ideas? Or is $1k not close to doing this?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 03-13-2020, 02:45 AM   #2
'10CamaroDude
Drives: 2010 Camaro LS
$450 or so. You need the face-plate kit. The kits are like $250, and you can get
a decent Android head unit for $200. I have an Eonon in my Mustang. If the Camaro
was not a work vehicle, I would put another radio in it. I am not spending $450
to hit a deer the next day...
'10CamaroDude is offline   Reply With Quote
Old 03-13-2020, 02:53 PM   #3
LCPLPunk
USA-1
LCPLPunk's Avatar
That's not bad, good to hear! I looked at the PAC kit, but I'm not sure I like how recessed the screen is.
Old 03-13-2020, 04:43 PM   #4
bottletalk
Drives: 15 Camaro 2SS M6
the idatalink cam1 is much better then the pac kit, best way to go imho!
bottletalk is offline   Reply With Quote
Old 03-13-2020, 04:57 PM   #5
LCPLPunk
USA-1
LCPLPunk's Avatar
Oh man, hadn't seen that one! I really like that one over the PAC!
Old 03-14-2020, 02:12 PM   #6
VeeGeeTea
LEXi is Sassy and Classy
VeeGeeTea's Avatar
Drives: 2012 Camaro 2LT RS Boston Acoustic
Get the iDatalink ADS-MRR2 and the KIT-CAM1 to replace the faceplate and retain your car's functionality, then invest in a Pioneer radio and the Pioneer rear cam. You don't need to cut or splice your wires as the kit comes with adapters and harnesses.
This should all be within your budget.
VeeGeeTea is offline   Reply With Quote
Old 03-14-2020, 06:23 PM   #7
boomerbsg
Drives: White 2010 Camaro SS Automatic
I'd like to chime in, and say if you dont need cd/dvd playback, look for Multimedia decks. they have a much smaller footprint and makes installing in these cars easier.
nothing cheap about the audio in the these cars if you want to do it right. i'm looking at about $300 for the install kit, and another $300-$400 for the head unit. i've already changed all my speakers, added a 5 channel JL M700/5, and a JL 10 inch W3 sub. I also sound deadened a lot, but have more to deaden when i do my head unit this year.
boomerbsg is offline   Reply With Quote
Old 03-15-2020, 01:12 PM   #8
LCPLPunk
USA-1
LCPLPunk's Avatar
Thanks guys!!!
Old 03-15-2020, 01:33 PM   #9
byrds8
byrds8's Avatar
Drives: 2013 Camaro 2SS, L99
The thread you commented in where the guy changed to a Kenmore headunit looks like it would be a good idea.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
byrds8 is offline   Reply With Quote
Old 03-15-2020, 01:36 PM   #10
LCPLPunk
USA-1
LCPLPunk's Avatar
Agreed! I just have to make sure I can hook up a rearview camera to it. I'm still in the initial stages of piece selection, so maybe the Kenwood already has that ability.
Old 03-15-2020, 04:52 PM   #11
byrds8
byrds8's Avatar
Post #18 in that thread shows the backup camera working so Id assume if you purchased the same items he did, yours would function the same.
Old 03-15-2020, 05:21 PM   #12
LCPLPunk
USA-1
LCPLPunk's Avatar
I don't have a camera though! I need to do more research on cameras compatible with Kenwoods. I'm sure they make them, I just haven't dove into that yet.
Old 03-16-2020, 07:29 AM   #13
byrds8
byrds8's Avatar
Here you go.
https://www.crutchfield.com/p_113CMO...-CMOS-230.html
Hope that helps. Those supposedly work with the HU in the other thread. If you look on the accessories tab for that HU, it gives you other options also.
Old 03-16-2020, 05:15 PM   #14
LCPLPunk
USA-1
LCPLPunk's Avatar
Haha, I saw that right after your previous comment. Looks like a pretty solid setup! I'm pretty excited!!
