![]() Drives: 2010 camaro limited edition turbo Join Date: Mar 2014
POST YOUR BOOST PSI ON LLT AND LFX
Since there are a lot of turbo and supercharger LLT & LFX members on the forum, I am interested in what PSI boost levels your projects are running, so could we use this thread to record those levels, as well as if any internal modifications have been made? I think it would be interesting to compile this information for those who are curious.
![]() ![]() Drives: 2014 1LS M6 Supercharged Join Date: Feb 2011
7 psi
I have (2) settings on my boost controller. 7PSI & 10PSI.
How much HP at those Boost settings and what did you do to the Engine to take the extra HP - Im at 400 to the wheels and a little reluctant to go higher
![]() Drives: SC 2012 V6 Join Date: May 2016
Running 16psi on stock motor
Supercharged V6 - 11.756 @ 122.75MPH
#6 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
#7 |
At the time for 16psi it was just methanol, injectors were added to try and run e85 for that boost.
#8 |
#9 |
Ran 16psi on 93 octane with methanol injection support, Will at Overkill did the tuning.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
8.49PSI
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
#11 |
That is sweet! Sorta figured Will did the tuning. He is one of the very best and a really nice guy. I met him and he knows his stuff. Your boost level is really unbelievable for 93 octane and meth injection. Crazy for a high compression engine with stock internals. Congratulations are in order! I'll bet that puppy is fast and is fun to drive.
#12 | |
#13 |
What a killer machine! I am so impressed and I have done a lot of FI installs! I may have to talk to Will about raising my boost. Love the HP!
#14 |
![]() ![]() Drives: 2015 camaro 2lt Join Date: Dec 2016
They can run much more, I've seen 30-40psi and 600-700whp out the lfx.
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5 Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85. |
