![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Fel-Pro valve cover gaskets...WTF?
So I am almost done with my cam swap and noticed something strange. My valve cover gaskets, which are 6 months old and only have 1600 miles on them have grown/stretched and no longer fit. It is like they grew over an inch. There is quite literally too much gasket. No matter what I do I cannot get them to fit.
Anyone ever experience this? I hate to trash a fairly new set of gaskets, but this is just ridiculous, especially from a company as well known as Fel-Pro. I will likely replace with OEM stuff.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS 2SS M6 Join Date: Aug 2016
had same prob....get sum new ones from Advance Auto for $20...
good luck! PEACE
I just did, unfortunately I had to go with Fel-Pro again because I don't want that to hold up completion waiting for the AC Delcos. But I had $5 in Speed Perks and the 20% off coupon code. Came out to $12.77. I can handle that for that price.
I just don't understand why they stretched like that. Anyhow, thanks for the heads up man.
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
I had the same issue.
I couldn’t reuse them because they stretched so much. Sent from my iPhone using Tapatalk |
I had the same issue "back in the day" and that is why I stopped using Felpro..
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Been that way for years, always considers Felpro valve cover gaskets a one time use item just like condoms .
OLD GUY FLYING FAST AND LOW
#7 | |
I honestly never knew that (The gaskets, not the condoms lol). I can totally understand a year or two, but I have put 1600 miles on this engine (First start was Last October) and they were totally unusable. That's lame. But overall it's not a huge deal since they are rather cheap. OMG, so close to finishing my cam swap. Just need to install the fuel line, fill the radiator, reinstall my coil packs, plugs/wires and my Vararam. I had to quit for the night as my back is killing me and I don't like working in the dark on my car. Too easy to miss something stupid. Oh yeah, and install the startup tune Ryan from GPI sent. First start has my nervous as heck.
#8 |
![]() ![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
When i took my supercharger out the factory brick gasket was so oversized i couldn’t use it. It was 1” bigger all around. Had to order a new one.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: 2010 SS L99 Join Date: Sep 2018
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
#10 |
![]() Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
+1
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
