![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
325/295 combo on 1Le
14 1LE lowered on BMR 1.4. Want to get 325/30r20 for rears and 295/30r20 for fronts. Will it work? Any pics? Rubbing issues?
![]() Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Are you just street or do you track it?
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
![]() ![]() Drives: Camaro Z28 Join Date: Jan 2017
This would work just fine as a street setup but will introduce more understeer on track. What tire model did you plan on using?
JJ - Fitment Specialist /// Forged Wheels /// Wheels For Your Camaro
Camaro Wheel & Tire Fitment Guides /// Defining Real Performance /// Camaro Wheel Gallery expert@apexwheels.com |
#4 | |
Whatever fits... I know different tires either same specs are totally different.. |
#5 | |
Tire fitment
I have a ZL1 with michelin Super Sports 295's up front and 315's in the rear. The car is lowered on BMR 1"lowering springs. I do not like the rear of the car lower than the front, so I made 1/2" spacers for the rear spring perch, so the car has a bit of a rake. I tried 1.4" BMR lowering springs up front but tires rubbed when turned. I think that 1/4" spacers in the rear would make the car level. Just so you know the front of my car is so low, as it sits now you cannot fit a soda can under the front splitter. Wheel specs for ZL1 20" wheels; Offsets: Front 20x10 - +23mm Rear 20x11 - +43mm Bolt Pattern - 5x120 More pics on my build journal https://www.camaro5.com/forums/showthread.php?t=571243 . Last edited by Vicster; 04-03-2020 at 08:12 PM. |
#6 | |
Ty. Awesome write up. I ended up just getting 295/35 & 315/35 pirellis, and a set of 325/40 DRs (18x11). Hopefully they’ll fit. As far as the 295’s rubbing, was it more during fully locked turns, or more of making a left/ right turn on the street? |
#7 | |
Rubbing
Glad it helped! Last edited by Vicster; 04-03-2020 at 09:00 PM. |
