03-22-2020, 11:53 PM | #1 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
SOLD: 2015 Camaro Green Flash special edition
For Sale: 2015 2SS/RS Green Flash Special Edition 1 of 811 Emerald Green Metallic 21 inch Split Chrome wheels HID/LED HALO Front Lamps LED Tail Lights Cyber Gray Rally Stripes ZL1 Spoiler and aero package A6 Transmission Stability Control Remote Start Steering wheel controls, Tap shift Premium Sound system Rear Vision Camera 1 owner, 29K miles, garage kept and pampered. This is a special edition car with only 811 produced, Emerald Green Metallic paint, special edition wheels and aero make this car a head turner. Exterior is stock, engine and drivetrain are modified but only at the track a few times for fun runs. Best ET 11.73 @ 115 mph with potential for more. She’s quick and really stands out cruising & car shows. Engine: GPI VVT SS1 cam GPI ported/polished heads milled .30 BTR .660 springs Straub solid bushing rocker trunnions GPI rod-mod intake with I-M heat shield Bo White stage 2 ported throttle body Vararam throttle body spacer Kooks stepped headers Solo XL Exhaust with hi flow race cats ADM Cold Air Intake w/race scoop Rotofab windshield washer relocation 169F thermostat & manual fan switch Mighty Mouse PCV catch can Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft Drivetrain/Suspension: Circle D 258mm Pro single disc 3700 rpm stall converter B&M deep trans pan JRE trans dipstick tube ADM transmission cooler Pegasus solid subframe bushings aFe PFADT Series rear trailing arms & tie rods 3.91 TruTrac differential w/poly bushings LPW IRS Ultra differential cover/girdle Body: Z28/ZL1 belly pan GM strut tower brace Escort Passport 9500ci stealth radar detector Ceramic window tint FlowTie front emblem All weather floor mats Camaro rubber trunk mat Startup and idle - https://www.youtube.com/channel/UCY4...CNKaf0rFMVEBZQ $26,500 OBO
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft Last edited by GRNFLSH; 05-19-2020 at 08:33 PM. Reason: added pics |
03-23-2020, 08:37 AM | #2 |
Drives: 2013 SS 1LE Join Date: Nov 2011
Nice car...nice price !!!
03-23-2020, 06:18 PM | #3 |
Drives: Iron Lung, Jimmy Join Date: Jun 2009
I just absolutely love that color.
03-23-2020, 07:04 PM | #4 |
Drives: 2006 BOM GTO Join Date: Jul 2018
Usually not a green fan of any color but dam does that look nice.
03-23-2020, 07:38 PM | #5 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Love that color had a Pontiac Bonneville SSEI the same color. Some lucky person is gonna buy this, wish I had the money for another one I would snag that up in a second
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
03-24-2020, 08:22 AM | #6 |
Any interior pictures?
03-24-2020, 12:06 PM | #7 |
Drives: 2013 ZL1 Join Date: Mar 2013
That is a beautiful car! I want to know where and how you got the flow tie to work on the grill. I did not think they would work on any grill except the Z/28 grill.
03-24-2020, 12:08 PM | #8 |
You bet. I just added interior and engine bay pics to the original post.
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
03-24-2020, 12:19 PM | #9 | |
03-25-2020, 07:48 PM | #10 |
Drives: 2013 Camaro 2SS RS Convt. Join Date: Mar 2011
Beautiful Ride! GLWS!!
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
03-26-2020, 06:17 PM | #11 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
Beautiful car. I love the green flash editions!
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
03-28-2020, 08:07 AM | #12 |
Happy Saturday! - Added a video link to the original post.
04-18-2020, 03:52 PM | #13 |
Bump, it’s Saturday, time to cruise!
04-18-2020, 06:29 PM | #14 |
Drives: Subaru Join Date: Oct 2008
Getting hard to find that color, love it! Wish it was a stick!
Time for a new ride soon....6th Gen or 5th Gen Z28? Hmmm....
