03-25-2020, 09:46 PM | #1 |
Drives: 2014 camaro 2ss Join Date: Dec 2017
Service power steering
2014. CAmaro ss I keep getting a message on the dic”service power steering with care” abs and brake light on and makes a ding ding ding. What’s going on? Ahall1 is online now Report Post |
03-26-2020, 12:24 AM | #2 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Have you had new tires installed?
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-26-2020, 10:20 AM | #3 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Could also be loose ground(s). Check the one on the head by the dipstick, also the one on the back of the driver's head.
I'm with dreksnot, though- what, if anything, has changed?
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // JMS // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
04-21-2020, 04:01 PM | #4 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
codes?
scan for codes will have a idea which direction to go in |
05-04-2020, 10:39 AM | #5 |
Drives: 2015 Camarovan SS Join Date: Apr 2020
I have this problem too.
From a service manual: Steering Angle Sensor Centering The steering angle sensor does not require a centering often. Centering of the steering angle sensor might be required after certain service procedures are performed. Some of these procedures are as follows: • Wheel alignment • Steering gear replacement • Steering column replacement • Steering angle sensor replacement • Collision or other physical damage • Electronic brake control module replacement The steering angle sensor centering procedure can be completed with a scan tool using the following steps: 1. Using the steering wheel, align the front wheels forward. 2. Apply the parking brake, or set the transmission in the Park. 3. Install the scan tool to the data link connector. 4. Ignition ON, engine OFF 5. Select Steering Wheel Angle Sensor Reset in the Steering Wheel Angle Sensor Module Configuration/Reset Functions list. 6. Follow the scan tool directions to complete the reset procedure. 7. Select Steering Wheel Angle Sensor Learn in the Steering Wheel Angle Sensor Module Configuration/Reset Functions list. 8. Follow the scan tool directions to complete the learn procedure. 9. Select Steering Wheel Angle Sensor Learn in the Electronic Brake Control Module Configuration/Reset Functions list. 10. Follow the scan tool directions to complete the Learn procedure. 11. Clear any DTCs that may be set. I bought an Autel MD808 and although it says it can reset SAS, it wouldn't on my 2015 2SS. So I'm currently looking for the cheapest scantool that can. Anybody successfully done this? Which scanner? |
