Old 03-30-2020, 01:16 PM   #1
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
rear suspension question
Hey guys. So bring me up to speed here if possible. I just did my poly rear cradle bushings and swapped out the rear diff. I have the entire rear suspension still loose. Im going to load it by either putting a block of wood and jack under the lower control arm or just throw the tires back on. That way I can torque everything down. Any input or advice here? Thanks
gunchamp is offline   Reply With Quote
Old 03-30-2020, 01:59 PM   #2
'10CamaroDude
Drives: 2010 Camaro LS
If you mean all the control arms, they get torqued at ride height. The cradle, if you
can, center it, block it, and tighten the bolts. That does not necessarily have to
be done at ride height. Anything with a bushing pivot point, gets torqued at
ride height.
'10CamaroDude is offline   Reply With Quote
Old 03-30-2020, 02:16 PM   #3
gunchamp
gunchamp's Avatar
ride height.
Thanks for the response. Got the cradle torqued and figured all the other rear suspension needs done fully loaded.
Old 03-30-2020, 09:23 PM   #4
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
Unless the car is on a lift it’s impossible to torque suspension with the tires on (challenge me if I’m missing something). I used a jack to raise the suspension until the car was starting to lift off the jackstand and then torqued.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 03-31-2020, 11:04 AM   #5
KillboyPowerhead
Drives: 2015 Z/22
You'd definitely need some extra height. If you don't have a lift you can use wood, jacking up the car and placing a board under the tires, going side-to-side one board at a time, or something. Would need a lot of wood though, perhaps.
I wonder if jacking up the suspension until the car lifts like you did might be too much, because the car won't start lifting until the spring is fully compressed, while when the car is sitting on the ground like normal the springs aren't fully compressed, ya know?
Personally what I did was because I had coil-overs and knew what ride height I wanted I just jacked up the suspension to that height (using the centre of the hub/axle as reference), then tightened it all down - it may not be exact, but in my experience when asking a tech to "reset the bushings" (or some variant of that) I usually get a rather confused look, so I felt more comfortable doing it myself.
KillboyPowerhead is offline   Reply With Quote
Old 03-31-2020, 04:04 PM   #6
gunchamp
gunchamp's Avatar
I was considering both ways. I do have the car up on some fairly large blocks of wood. So I may just throw the tires back on and torque it that way. I was also considering the jack method as well. Curious myself if that puts more load on to the suspension than just resting on the tires.
Old 04-01-2020, 07:27 PM   #7
KillboyPowerhead
Drives: 2015 Z/22
It's not about the load/weight but rather the angle of the suspension arms. If you have the suspension hanging down all the way, for example, and crank everything down, when the car sits on the ground the suspension will raise, and all of the rubber bushings will get torqued/twisted. If the bolts/bushings are all torqued down with the suspension arms at normal ride height, all is good. Ideally you'd have the car on the ground so that there's no guessing, but if it's too difficult then taking a guess based on the advertised drop (or whatever ride height you want if you have coil-overs) will be pretty close.
Old 04-03-2020, 02:21 PM   #8
gunchamp
gunchamp's Avatar
Good point here. I'll just throw the tires back on and torque it that way. I have the car up on some big beefy wood blocks, so access shouldnt be too much of an issue.
Old 04-07-2020, 10:03 PM   #9
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Also depends, parts with poly bushings now in them wouldn't need to be loaded as the sleeve will spin, so just the parts with the bonded rubber bushings would need to be loaded. I just used a jack under the lca by the knuckle to load the suspension and torque what was needed
Greenhornet2 is offline   Reply With Quote
