Old 04-03-2020, 06:45 PM   #1
Axe55
Drives: 2012 Camaro SS
Trailing arm and toe-rod install?
Hey folks, so I'm getting ready to install some BMR trailing arms and non-adjustable toe-rods with polyurethane bushings, and of course, I waited until Friday evening to read the instructions. Both sets of instructions say I need to pump some grease into the bushings after installation, but does not specify what type of grease. Anybody out there know what type of grease I should be using? Also, as the years go by, any advice on how frequently I should re-grease these bushings?
Also, from what I've read, both on the forums and in the instructions, I'm a little unclear on whether or not it matters if I torque all the bolts with the suspension loaded or not. All of the bushings I'm installing are polyurethane from BMR, not rubber. From the instructions, it looks like I can torque everything before I lower the vehicle as long as I mark the original position of the inner bolt on the toe rods. Any advice on this out there? Thanks.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
Axe55 is offline   Reply With Quote
Old 04-03-2020, 06:58 PM   #2
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
You need synthetic grease. BMR supplies this also. You need to look at the sticky thread in the suspension section about clocking the bushings. I have BMR toe rods and trailing arms and did them myself
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 04-03-2020, 07:59 PM   #3
Axe55
Thanks for the reply sir, I read the sticky, it's the same for rubber bushings as polyurethane? Looking at the pictures in that thread, the rubber there looks pretty squishy and the polyurethane ones that I have are hard, same process for both?
Old 04-03-2020, 10:18 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Yes same process only ones you don’t have to do are links with spherical bearings.
Orange Krush II
