![]() Drives: 2010 ss/rs 6 speed manual Join Date: Aug 2013
What o2 sensors to use?
Ok part of my summer plans for my car is to put on some 1.7/8” or 2” long tube headers. I am getting a set of high flow cats this weekend to go with new headers. While I’m doing this my car just hit 100k miles so I figure it’s a perfect opportunity to do some preventative maintenance and replace the o2 sensors. I know I will need a tune for the cels that pop up. But with all this in mind is there a certain brand or type of o2 sensor I should use?
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
In the tune the rear o2 sensors will be turned off and thus no CEL. If you want to replace the fronts go with Ac Delco.
More to come. Last edited by Black_SS10; 04-08-2020 at 06:35 PM. Reason: Clarification |
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
My car has 75k and when I did my headers I put in acdelco ones, paid $70 for both fronts I think from amazon. No reason to not use OEM ones
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Cool ac Delcos it is then. Thanks. Wasn’t sure there wasn’t a better one out there. Just thought I’d get opinions or choices never really dealt with o2 sensors before.
Think of it this way - yours lasted 100k miles without a problem. Why not continue that stretch with the same parts.
#6 |
True thanks for the info.
#7 |
I have hi-flow cats, and spacers, and the rear bank 2 O2 sensor still throws a
P0430 code. I can't tune them out, I am in an emissions state, and they show up as "Not ready." The state only allows for one Not Ready status. May be due to the crap O2 sensors they SAY they replaced, but I don't think thay actually did anything with the O2 sensors. That Dealz on Wheels place said they dumped $1700 into the car and still could not get rid of the CAT codes. Well, that's because they have no idea what they're doing, and they did not use OEM Cats. One of the cats, rear cat bank 2, is damaged. They had the car for TEN weeks, and still didn't get the stuff done. I got a crap hand written small yellow receipt from a pad with all the parts they SAY they replaced. I asked for the WORK ORDERS from the garage that did the work, they refused. There would be receipts with the parts they claim they bought, I wanted those too, they refused. Last edited by '10CamaroDude; 04-08-2020 at 07:53 PM. |
#8 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I must say, I've never seen a copy/paste approach to a forum before this guy. It's an interesting approach. ��
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
I have had great luck with the Denso sensors.
#10 |
#11 |
Started#gottalovethatblue
I'm running ACDelco still without any issues (cammed, full bolt on car). The best price I found was www.rockauto.com. They were less expensive for ACDelco than the knock off brand at the auto parts store.
#12 | |
#13 |
![]() Drives: 2014 Chevy SS Join Date: Nov 2014
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4 2014 Chevy SS --- 429ci Hydraulic Roller LS3 |
#14 | |
Also AutoZone and probably O'Reilly's as well. KW
