Old 04-10-2020, 09:45 PM   #1
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
15" V6 Brakes for SS
I've heard that V6 brakes can be installed to save some $ on the 15" conversion. Has anyone does this, and ran Forgestar D5 beadlocks? Any information on if this is possible would be awesome. Thank you.
Cornflakes'Camaro is offline   Reply With Quote
Old 04-13-2020, 01:59 PM   #2
eLeSthree
Drives: 2011 Camaro SS 6sp
Bump for answers. I'd like to do the same.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 04-13-2020, 02:31 PM   #3
Cornflakes'Camaro
I've tried searching but no luck. Hopefully someone chimes in with experience doing so!
Old 04-13-2020, 10:14 PM   #4
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
So I haven't done it but since nobody's chiming in I'll try to point you in the right direction.
If I remember right a couple of the guys from GPI did it including Ryan at one point. Not sure what 15's they ran but seems like they had to grind on the calipers after getting the correct LCA's or cutting on the ones they had. Can't remember what way they went there. Chris49066SS is only on here occasionally but probably remembers more than I do about it. Or if you are really fortunate someone else who has done it will give some pointers. I know somewhere here on C5 it's talked about what was done to make it happen. Sorry couldn't be more help but certain it can be done. GL
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 04-13-2020, 10:41 PM   #5
Cornflakes'Camaro
Thanks bro! Continuing the search.
Old 04-13-2020, 11:51 PM   #6
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
I spoke with the guys at GPI on this last year. They used the stock LCAs and had to do quite a bit of grinding on the LCAs and trailing arms but were able to clear the wheels they used, but theirs were Welds. If I were doing mine, and I am eventually, I would/will just spend the money so I can do lightweight brakes and Welds and save rotational mass the first time and not have to spend money twice. Good luck with this though, its a good idea if you can get it to work.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 04-14-2020, 07:17 PM   #7
eLeSthree
Not trying to hijack here, but my question (and maybe the OP's) was not so much about suspension. I have no problem buying the BMR Drag pack with LCAs and trailing arms that fit 15inch wheels.
I just wanna know if V6 brakes can be swapped out for my SS brembos fairly easily, and clear 15inch wheels.
1158whp 1017wtq.
630whp 658wtq
Old 04-14-2020, 07:37 PM   #8
Chris49066SS
Drives: 2010 SS L99
I remember them saying something about having to do a little bit of modification to the V6 calipers but nothing too crazy that you wouldn't be able to do yourself. I would have went this route had I not decided on the Aerospace lightweight brakes. The best thing would be to give GPI a call and ask how that was done then you'd have the info right from the horse's mouth
Old 04-14-2020, 08:07 PM   #9
Cornflakes'Camaro
Will do sir. Thank you for that. ELesthree you are exactly right my man! I already have everything needed. Just deciding if I need $650 brakes or if I can get some V6 ones and just grind a little.
