04-14-2020, 03:28 PM | #1 |
Drives: 2013 2ss hotwheels Join Date: Aug 2014
BTR stage 3 plus 3.91 or 4.10 or4.11
What are advantages or disadvantages of these combinations
04-14-2020, 05:55 PM | #2 |
Drives: 2014 2SS/RS Join Date: Jan 2018
To start with I have the TSP Stage 3
Now the gears.. There isnt much difference between the 3.91 and the 4.10. I have 3.91. I chose to go 3.91 because it's cheaper, more readily available, and oem if you buy the GM gears. They drop in super easy with little to no shimming or anything. Some of the 4.10/4.11 gears out there had a bad rap and I decided it wasnt enough of a difference to me to try it. They cost quite a bit more too. Numbers to numbers the lower of the two are better for cammed cars but to me the other stuff outweighed that. I love my car the way it is set up. I daily drive it with the exception of huge storms or blizzards.
2014 2SS/RS LS3/M6
04-14-2020, 06:14 PM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Personally I'd just stick to the 3.91s. If you're really into drag racing at the track that's a different story.
04-14-2020, 06:45 PM | #4 |
Drives: 2012 Camaro SS Join Date: Dec 2019
How are 3.91’s for daily driving? And at a higher horsepower 600+ rwp are they still good?
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-14-2020, 07:04 PM | #5 |
I opted not to do the gears due to the HP i fight traction enough as is. I'll stick with stock.
04-14-2020, 09:54 PM | #6 |
I want to send my rear end to jre and have them rebuild it. My installer said new gears would wake car up. I'm assuming they would be quicker off line but I don't want to sacrifice top end. It's not a DD couple times a month
04-14-2020, 10:01 PM | #7 |
My car puts out 500rwhp and I love the gears. Traction in these cars is an issue though. Wider tires and other things can help. I feel like they should have came with the 3.91s in the m6 cars from the factory.
2014 2SS/RS LS3/M6
04-14-2020, 10:30 PM | #8 |
Factory gears?
04-14-2020, 10:34 PM | #9 |
I've also got Michelin pilot ss20x315 out back
04-15-2020, 05:30 AM | #10 |
Go with 3.91. I mean it's impossible not to lose top end going with a lower gear but i don't imagine you are trying to do 200mph. 3.91s work great at the track and are still reasonable on the street everyone seems to love them. They are readily available.
04-15-2020, 09:38 AM | #11 | |
Started#gottalovethatblue
See above comment in this post. GM makes 3.91 gears as a swap in because it is a GM available part.
04-15-2020, 09:44 AM | #12 |
Not what I was talking about. The 1LE has a different transmission gear set entirely and final drive ratio ends up being similar.
2014 2SS/RS LS3/M6
04-15-2020, 10:44 AM | #13 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
I like the 3.91 gears. Got them to help acceleration out of turns doing autocross. And they get the car going on the street, especially if you have list bottom end torque from a big cam. It helps even with my little stage one cam. Penalties are only 200 rpm higher freeway rpm and at 65-80 mph on open roads, 1 mpg loss
04-15-2020, 10:57 AM | #14 |
Auto go 3.91
M6 go 4.10 |
