Old 04-17-2020, 11:37 AM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
LT1SC vs LT1S Triple
Anyone have experience with these 2? Monster recommended the triple for my street application. Seems a little excessive for my needs.
RupertPupkin is offline   Reply With Quote
Old 04-17-2020, 12:35 PM   #2
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
From my discussions with Monster, the S triple will have much better street manners than the SC twin and is what I will be going with when I get a new clutch this year. Depending on your power goals the S twin is rated at 700hp and will have good street manners.
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 04-17-2020, 01:29 PM   #3
RupertPupkin
I’ll be at 750-850rwhp. That’s what they say also. My tolerance when it comes to drivability is pretty high. My cam is pretty big, and I didn’t mind it when I DD the car.
Old 04-17-2020, 05:32 PM   #4
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
You have to decide if you can live with it or not. I'm shooting for similar power levels and just going to go for it and get the S triple because I want the drivability, and it should be easier to slip during launch and last longer than the SC twin.
2014 1SS/1LE
Old 04-19-2020, 11:46 AM   #5
RupertPupkin
That’s what I’m trying to figure out. 1700$ for triple or 1430$ for SC w/ slave. 270$ not bad .
Did you keep your stock slave?
Old 04-19-2020, 01:44 PM   #6
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
I haven't got it yet, planning to get a new clutch later this year. The triple comes with a new slave, it doesn't use the stock style slave in our cars.
2014 1SS/1LE
Old 04-19-2020, 02:43 PM   #7
RupertPupkin
I asked monster and they said I can keep my stock slave...
Old 04-19-2020, 03:35 PM   #8
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
For the triple? This is what they said when I asked about it. sounds like the slave isn't a stock one and it's included with the triple kit
The triple, at $1899, will include a new GM conversion slave cylinder, flywheel, complete clutch assembly, pilot bearing, and alignment tool.
2014 1SS/1LE
Old 04-19-2020, 04:28 PM   #9
RupertPupkin
Yeah, I get that. I just got the response from them an hour or so ago.
Old 04-19-2020, 06:20 PM   #10
RupertPupkin
Stand corrected. The slave is required.
Old 04-20-2020, 11:52 AM   #11
RupertPupkin
“we use GM slaves.
We charge what we do because we cover the clutch under the warranty if the slave cylinder fails - if they fail it kills all three frictions in the clutch.” -MONSTER
I guess it’s for warranty reasons.
Old 04-20-2020, 12:34 PM   #12
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I have a triple ready to go in to my build. Hopefully i'll be driving it in the next week or two.
Old 04-20-2020, 12:48 PM   #13
RupertPupkin
What made you go with the triple instead of the SC?
Old 04-20-2020, 01:04 PM   #14
larry_g
larry_g's Avatar
Mostly because of the reviews regarding street manners as mine will still be a daily driver. That and I found it for a price that was too good to refuse.
I also bought a new slave with billet bearing support and the remote bleeder while I was at it.
