04-17-2020, 04:08 PM | #1 |
Drives: 2014 white z28 Join Date: Apr 2019
Front seats
Could some one point me to the information to remove my front seats please
04-17-2020, 05:38 PM | #2 |
Drives: 2015 2ss Join Date: Jun 2009
super simple:
1) DISCONNECT BATTERY! you don't want to run risk of airbag discharge 2) pull both seats all the way to the front of the car (both bottom and back) and then undo (2) TORX bolts at the back of each seat corner (you'll see them once you're in the back seat at this point pulling out the seat.) I can't recall the Torx size, it was either T30 or T50, either way bring a set of T bits with you. 3) Once you pull 2 bolts for each seat, pull each seat TOWARDS the back of the car and the front of the seat mounts will "un-hook" themselves from the bottom of the floor. ) at this time you'll also want to locate the airbag/heated set connector that goes from the seat to the chassis. Grab the side of the connector and slide it out like 50%, you'll feel the seat start to disconnect from the connector, carefully make sure the connection has opened so you can separate the seat from the car. just a friendly heads up: when you remove / put the seats, be very careful the bottom of the seat frame doesn't scrape the steering wheel, i did this by accident and scuffed my wheel. luckily that was my old leather wheel before i swapped to a alcantara wheel.
2015 Camaro 2ss, NicKey Performance built/tuned |
04-17-2020, 07:39 PM | #3 |
Thank you very much David
