![]() Drives: 2012 2SS/RS L99 Join Date: Apr 2020
Average lifespan of Gen 5 SS brake rotors?
Seems I end up changing pads every time I get tires, around 25-30k miles. I resurfaced the rotors on the last brake change but didn't this time because they'd been done twice already and I was concerned about thinning them out. How often do you replace rotors? I use OE semi metallic pads.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
All depends on how to drive it. I have 33k on original pads and rotors. Still not past half way on pads.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
I don't autocross or anything like that but I do take advantage of their capability on occasion. I wonder if yours wear slower due to your manual trans vs my auto?
I just recently had my original rotors and pads replaced at 60k. Fronts only. Still on original rears. Developed a groove in one of the front rotors so couldn't be resurfaced.
#6 |
It don’t come easy.
A manual trans can be used for braking where an auto can’t, as far as I know. I have 39k on my car and pads and rotors look fine.
#7 | |
How much of a lip do you have at the edge of your rotors? I have a pretty pronounced one, but I don't know if that's normal or not for my mileage. |
#8 | |
That's what I was thinking too. I DD mine and have to deal with some stop and go traffic most days, I just wasn't sure what normal rotor wear was. Pads are cheap enough and easy enough to change but I'm sure rotors are an investment. |
#9 |
![]() Drives: 2014 Chevy Camaro SS Join Date: Mar 2015
Did the standard brakes change in 2014? I have ceramic pads on my 2014, and when the pads wore out, the garage manager told me they had to replace the rotors at the same time because they wear at the same rate as the pads. He said that's how they're such great brakes, they are engineered that way. He also said my brakes are pretty much the same as what is on the Corvette. It was so freakin' expensive when I had to have done!
#10 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Got about 53000 miles on my original rotors. Definitely were under spec. Includes seven years of 10-12 autocross events per each of those years. As to Pads , on third set.
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
#12 |
I changed my rotors after 50,000 miles were on them.
SOLD: 2010 2SS/RS L99-A6
K&N CAI, Speed Engineering Long Tube Headers, Stainless Works hi-flow cats, Flowmaster American Thunder Cat-back. Tuned by Corvettes of Westchester. 1/LE rear suspension conversion, Bilstein B6 Stuts/shocks. |
#13 |
Sorry, just seeing this. No pronounced edge on the new ones, pretty smooth to the edge. I have on the rear what you're describing.
#14 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
Depends how you drive. I have 46K on the original pads and rotors and as of last inspection still have plenty of meat left on the pads. Rotors are smooth also.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
