Old 04-19-2020, 04:08 PM   #1
KenBaker
Drives: 2010 Camaro SS
How do you get the Rack and Pinion out of a 2010 Camaro?
I removed everything from it and cannot slide it out of the vehicle. The Steering Shaft is on the other side of the Frame and will not clear anything. I am sure there is a trick that I cannot visualize. Everything is unhooked and I can slide it about 6 inches towards the Drivers Side
KenBaker is offline   Reply With Quote
Old 04-19-2020, 04:39 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I’m sure you took outer tie rods off correct? Might need to slid as far over to passenger side an then tilt it down to slid under the frame on driver side and might also have to lift engine up a bit after loosening mount nuts.
Orange Krush II
Old 04-19-2020, 05:36 PM   #3
KenBaker
Thanks for the reply. The Outer Tie Rods are not really a factor anywhere. I am having problems removing the Inner Tie Rod on the Drivers Side.
