Old 04-19-2020, 08:55 PM   #1
pistolaccents
pistolaccents's Avatar
Drives: 2010 Camaro SS LS3 6 Speed Manual
Cam choice on my build
2010 Camaro SS w/ 6 speed
My ls3 blow last winter. So I decided if I need a motor , do a stroker I purchased a Katech 416 short block with callie crank and rods and Mahle pistons w/ valve reliefs. My heads were sent out to a guy that chambered and polished them , he actually did 1 chamber by hand then made a cnc program to duplicate the rest. From what I understand the heads are chambered @ 64cc not sure what the flow is.
The car already has :
American racing complete exhaust w/ long tubes and cat deletes
Fast 102 intake
102 throttle body (nick williams)
4:10 gears
Melling oil pump
PAC valve springs triple
Gm hi performance roller lifters
I am installing a mitsimoshu aluminum radiator
ATI balancer
Doing the numbers with the gaskets And the cc’s from the heads we should be around 12:1
My tuner decided on a cam by going back and fourth with the guy that did the heads and another tuner and came up with this
224/236 .646 lift and a 117lsa
Cam was made by LSM
The head guy wanted to see a bigger cam but my tuner said this spec is a nice running and ‘fun’ build..
this car is just a weekend driver and something to mess with the mustangs
Oh yea gonna spray a 150 shot also if needed...
My old cam spec was 226/234 .621 114 lsa that cam was prior to doing the heads and on the stock motor.. you heard the cam and felt it also.
I guess my question would be will this cam feel and sound the same?, stronger?
I know performance wise I will gain all across the line I think
2010 Camaro SS 2 SS ... Katech 416 Stroker Motor, ARH LT Headers, 4.10 Rear End w/ LPW rear end cover, CAI Cold Air , MGW Shifter, ARH Complete Exhaust Cat's Deleted, Tuned by Chuck Corvette of Westchester, Cow Booster
Cam Upgrade, Fast LSX-R 102mm Intake, Nick Williams 102 TB, Holley Fuel rails, Elite Engineering Catch Can, Katech Aluminum valve Covers and Coil Relocation kit, Taylor Ignition Wires, ATI Damper, 1- Piece Driveshaft by G-Force, Nitto 315 / 275 Tire Set up, Foose Impala 168 Rims, BMR 1" lowering springs w/ Bilstein Struts, New Tune by Chuck
pistolaccents is offline   Reply With Quote
Old 04-19-2020, 09:02 PM   #2
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
so is it going to be a 416?
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 04-19-2020, 09:14 PM   #3
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I mean you aren't really comparing apples to apples. But i mean the car is going to pull harder now than it did before without question lol.
Greenhornet2 is offline   Reply With Quote
Old 04-19-2020, 09:17 PM   #4
pistolaccents
From what my builder / tuner says we will be closer to a ls7 (427)
Old 04-19-2020, 09:19 PM   #5
pistolaccents
My concern is the new cam choice. Not clear on the numbers
Old 04-19-2020, 10:36 PM   #6
RupertPupkin
Drives: 2014 Camaro SS 1Le
That’s like a stage 1 cam in an LS7... For my C6Z I have 233/245 652/635 113+3. This pulls like a freight.
RupertPupkin is offline   Reply With Quote
Old 04-20-2020, 03:33 AM   #7
Bo White
Bo White's Avatar
Any stroker needs at least 23X* intake duration.
A 235/248 would be bare minimum if I were building something. Also tighten up the LSA from 117* unless going to a positive displacement blower later. Say 113* or tighter.
Old 04-20-2020, 06:45 AM   #8
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
This is the cam I had ground for my 416....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 04-20-2020, 07:00 AM   #9
Greenhornet2
Have to defer to the guys with stroker experience here!
Old 04-20-2020, 08:59 AM   #10
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Bo is spot on. Need a lot more duration for the extra displacement. And the LSA is too wide for an N/A motor.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 04-20-2020, 09:17 AM   #11
62nalide
62nalide's Avatar
Drives: 2013 SS
Fast 102 intake
4:10 gears
Melling oil pump
ATI balancer
Cam was made by LSM
Idk about those specs for your setup.
62nalide is offline   Reply With Quote
Old 04-20-2020, 01:56 PM   #12
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
With a 12:1cr stroker, you're playing children's games with that tiny cam.
I went with a very mild cam for my stroker.....234"/254*, 115* + 4* with 11.5:1 cr.
I have two more dynos I want to put the car on, but the first dyno came in at 532hp/496tq to the wheels.
This is the 4th cam I've put in the engine....and it pulls hardest....harder than the LLSR that it replaced.
With a srtoker, and 12:1cr, I'd DEFINATELY go with more cam.....and no more than a .035" head gasket.
BTW....my heads/cam 6.2 LS3 in my Impala specs at 11.3:1 compression with a 229*/242* cam.
Best of luck with whatever you end up with!!
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 04-20-2020, 09:22 PM   #13
pistolaccents
Thanks for the input.. it’s discussion time with builder
Old 04-20-2020, 10:49 PM   #14
zz430camaro
Drives: 2015 1LE
The cam is way too small for a 416 and the LSA is too wide at 117
