Old 04-20-2020, 11:53 AM   #1
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Oil recommendations
So i'm around 650-700whp. I'm looking for an engine builders input here. What oil weight would be recommended. SBE, mods in signature. I was thinking a 5w-40 rotella i know it's a diesel oil but i have no cats so the extra zinc shouldn't hurt. Or a 10w-30? 10w-40 even? Just not sure if the weight should be changed much when pushing this kinda power.
Greenhornet2 is offline   Reply With Quote
Old 04-20-2020, 12:40 PM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
Im very similar in build and my tuner/shop recommend me pictured below.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 04-20-2020, 12:50 PM   #3
gtstorey
Wouldn't the weight recommended be based more of the clearances inside the engine more than power levels?
Old 04-20-2020, 01:05 PM   #4
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
My tuner/builder says 10w30 Amsoil ZRod.
SSEssence is offline   Reply With Quote
Old 04-20-2020, 02:11 PM   #5
Greenhornet2
From what I've gathered Increased stress on the internals can require a more viscous oil. That in turn also creates a bit more pressure to fight the stress and movement so hard parts don't contact bearings.
Old 04-20-2020, 02:36 PM   #6
Little Walter
Drives: ZL1
Even making 650 or 700 rwhp I still would use 5w30 Amsoil Signature Series. I recommend staying with the OEM recommended viscosity 5w30, GM engineers got it figured out with clearances and oil passages what will protect, work and flow best. According to Amsoil the XL is great but does not provide as good of wear protection as the Signature Series in any way, the XL does cost less. As GTStorey mentioned above the power does not matter as much as bearing clearances, oil passages, assuming at this horsepower level this is a stock engine with increased boost, headers and possibly a Heat Exchanger.
Little Walter is offline   Reply With Quote
Old 04-20-2020, 03:21 PM   #7
bayarea408
bayarea408's Avatar
Drives: T
X2
5w30 amsoil signature series
bayarea408 is offline   Reply With Quote
Old 04-20-2020, 03:37 PM   #8
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
I use Amsoil for everything and have for years. They make it in Duluth, MN about 50 miles from where I live. Great products.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 04-20-2020, 04:30 PM   #9
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Driven LS30
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 04-20-2020, 05:26 PM   #10
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
+1
0stones0 is offline   Reply With Quote
Old 04-20-2020, 05:32 PM   #11
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
I’m in the same hp range as you. I use Pennzoil ultra platinum 5w30
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 04-20-2020, 05:32 PM   #12
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
Similar build here +nitrous. Amsoil 5w30
2011 Camaro 1SS
Whipple Supercharged 1150/1100 @ 24psi - Removed blower and went Turbo
Huron Speed T6 1135/1070 @ 20psi so far. 15 more PSI loading...
Aries240SS is offline   Reply With Quote
Old 04-20-2020, 05:59 PM   #13
Big Biscuits
Big Biscuits's Avatar
Drives: 2010 1SS LS3
Amsoil here...5/30
2010 CGM 1SS
408/4L80E/ZL1
Vortech V-13 94C
Big Biscuits is offline   Reply With Quote
Old 04-20-2020, 07:54 PM   #14
Rons1le
Rons1le's Avatar
Ok, well I just ordered 5w30 signature series. Asked shop and they said if your not road coursing it this year get the 5w30. Added severe gear basically for free..
