![]() Drives: Chevrolet Camaro Join Date: Apr 2020
The Ryobi 1600 PSI Electric Pressure Washer Review
If you are a person who loves to see outdoor furniture and exterior walls cleaned and bright, you should not ignore a pressure washer. It is not just about keeping your house and job site cleaned; it is by far about saving cost. Today, we will provide a review of Ryobi 1,600 PSI 1.2 GPM Electric Pressure Washer, an ideal item for millions of modern homeowners.
The Ryobi pressure washers: Ryobi is a well-known manufacturer in specializing outdoor tools and products, including electric pressure washers. When talking about Ryobi, experienced users often provide positive feedback on the durability and effectiveness of their products. If you are confused between the differences between gas-powered and electric-powered pressure washers, the simple tip for choosing the right one is: pick the electric ones if you would frequently use them for light-duty cleaning duties. Otherwise, the gas-power ones work best for heavy-duty work. ![]() Benefits of using a pressure washer:
This 1600 PSI 1.2 GPM Electric Pressure Washer is designed ideally to remove mildew, mold, dirt from many different exterior surfaces, including bricks, fences, stone walls, and house exteriors. It can also be used to wash outdoor furniture, grills, window screens, door, garden equipment, etc. One important point to keep in mind is, this machine is not designed to clean indoor surfaces. Nowadays, pressure washers are used more often than before. We have to recognize that the Ryobi 1600 PSI Electric Pressure washer is one of the top best items to use for saving time, money, efforts, water resource, and labor. Ryobi 1600 psi pressure washer reviews This Ryobi 1600 pressure washer operates at 1600 Pounds Per Square Inch (PSI) and 1.2 Gallons Per Minute (GPM), which is the most common pressure and flow measurements for regular use. Key features:
Everything has 2 sides, so does having a pressure washer. The good point is, the pros outweigh the cons, and you will never regret owning one for your house. Pros:
![]() Average customer ratings:
Final words: Having a Ryobi 1600 PSI pressure washer is a great way to save your time much in cleaning outdoor house exteriors, doors, grills, garden equipment, and more. If you are living in a home with a garden, there will be nothing better than having a Ryobi 1600 PSI pressure washer for long-term use. If you find this review helpful, feel free to share this with your friends. Last edited by MikeKnopfler; 03-29-2024 at 05:04 AM. |
Keeper of “THE list”
If you can find one, I have the GM ground effects kit on my car. I was always partial to them and was glad to find one.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
I recommend that you do some research on Duraflex products. I have heard of serious fitment issues that require professional adjustments.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
Banned
Drives: cheby Camaro Join Date: Aug 2019
I recently seen a white RS with a kit like Pyros, very nice looking. They got the look right with that kit. One of the nicest looking 5th gens I ever seen. I was excited trying to catch the car but traffic was too heavy, I wondered who kit it was. My rear tires were worn down hard and I just spin all over the place.
Scott's45
Drives: 2012 2SS 45th Anniversary Join Date: Mar 2012
i think the ones from 3Dcarbon are very tasteful and look great. although i prefer the GM version, but those can't be found anywhere anymore.
#6 |
![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2016
Full ZL1 conversion
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit |
#7 |
Instagram: Sangstah
Duraflex requires installation, bondo, fitting by a body shop to install, not just simple bolt on.
#8 | |
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
#9 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Too bad you were not looking about two weeks ago as there was a complete GM kit available.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
#10 |
I just pieced together my own, ZL1 rockers and these rear lower spats from 3D Carbon.
https://www.phastekperformance.com/2...ower-skirt.htm
#11 |
I installed some Duraflex body parts ages ago and this was absolutely the case. It took quite a bit of time to massage the panels into place and get the contours to match right. After I blasted two deer and destroyed the front end I replaced with a high quality ABS which fit right on and was ready for paint. I will give the Duraflex one thing, it does take a punch much better than "normal" fiberglass.
2010 Camaro 2SS
2018 Charger GT+ 2005 Cavailer LS S/C - Sold '87 HD FXRT - Wrecked pending repair |
#12 |
I agree with the original Ground effects, but they are hard to find. I hope I never mess mine up.
#13 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Had to have the 3dCarbon set early on. Bought the side skirts and the rear slats. I still have them on... if I ever had to swap them, I'd consider the IKON set... looks great also.
I didn't get the 3dCarbon front splitter... wasn't for me. I installed 3 other splitters that shattered before finally swapping the front end to ZL1. I am still very happy with the result. Still enjoying and loving the look of this ride. The hood completed the look... at least for now. The MRT Louvers still look great... my diffuser is an IKON I modified to fit quads and the 3dCarbon slats. Every time I come home, I see the nose sticking out of the carport, and still think 'damn'....... I had a good looking Ashen Gray 5th gen behind me today on I15 as I drove home in the F150... still a very sexy, very good looking car. |
#14 |
Instagram: Mr2Hard2See
Drives: 2011 2SS/ RS Join Date: Apr 2018
I have 2 of the original stock ground parts I’d be willing to sale if you really want them but a pending sale is set for Friday. I can send you pics. Chin spoiler and rear diffuser but the rear diffuser is in roughy shaped the tabs have been broken unfortunately but fixable. Much less work than a duraflex item that’s for sure though.
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242 BTR dual springs pushrods lifters retainers etc Che bronze trunnion Ls3 timing/valley cover Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers |
