Old 04-22-2020, 12:15 AM   #1
dadsz28
dadsz28's Avatar
Drives: 5th gen pending
Et difference with 3.91s
Hey guys I am on the fence on doing 3.91 gears on my cammed and stalled Camaro car runs mid 11s. Can anyone give me what kind of improvement in ET they have gained. From what I gathered around .2 tenths?
Figured I would ask for anyone who has done it thanx.
dadsz28 is offline   Reply With Quote
Old 04-22-2020, 09:27 PM   #2
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
.150 gain in the 1/8th mile. No 1/4 mile track near where I live. Car runs 7.1-7.3 in the 1/8th depending on prep/DA.
I ended up having to remove the first set I put in, Motive. Too much gear whine. Many others have experienced the same regardless of how well they are installed.
Went with AAM and they were originally quiet. Developed a slight gear whine over time, but much less than Motive.
I'd highly recommend swapping out the factory clutch pack differential with an Eaton True-Trac when you do the gear swap.
It will still depend on which cam/stall you have as to what rear end gear will work best. 391's do work for a wide variety.
Shift points will need adjustments, as well as speedo.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 04-23-2020, 09:11 AM   #3
62nalide
62nalide's Avatar
Drives: 2013 SS
I saw a solid .15 gain going to 3.91s on a H/C setup 2mph gain
62nalide is offline   Reply With Quote
Old 06-06-2020, 02:53 AM   #4
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
I thought mph would drop with 3.91s?
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91
Bo White throttle body Magnaflow Competition Exhaust
12.391 112 MPH 10/05/19
StingrayblueSS is offline   Reply With Quote
