Old 04-22-2020, 10:31 AM   #1
Pearlj10
Drives: 2011 Camaro 2LT
Straight pipe options to replace HFC
I’m seriously thinking of pulling the trigger on the Overkill stage 1 SC. I don’t want to run the risk of burning up the BBK high flow cats behind the LT headers. Any options still available that would be a simple R & R process (that bolts up nicely to the header flanges) to get rid of the cats? Thanks
Pearlj10 is offline   Reply With Quote
Old 04-22-2020, 12:18 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
If your state doesn’t require smog emissions go with a cat delete. My county requires emission tests so I run the stock cats.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 04-22-2020, 01:54 PM   #3
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Go to a exhaust shop and they will just remove your cats and weld in a pipe. Should be under $100 for parts and labor
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 04-22-2020, 03:16 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
+1, it doesn't look like BBK sells a catless variant so you couldn't ask them to purchase cat deletes that would match.
DSX_Camaro is offline   Reply With Quote
Old 05-21-2020, 07:16 PM   #5
'10CamaroDude
Drives: 2010 Camaro LS
So does mine, but I removed the secondary cats. They're not monitored.
Car runs fine, and I just passed PA emissions today. Some places may
look, and see the tampering, and fail you. However, they should see that
the primary cats are still there. They're cheap hi-flow down-pipes too,
needed spacers.
'10CamaroDude is offline   Reply With Quote
Old 05-21-2020, 08:06 PM   #6
DSX_Camaro
DSX_Camaro's Avatar
needed spacers.
High flow metal cats will melt with a supercharger.
Old 05-31-2020, 02:21 AM   #7
'10CamaroDude
The CAT material my melt, but the pipes and CAT housings won't. Then
you will have catless down-pipes if all the substrate is melted out.
Old 05-31-2020, 07:30 PM   #8
DSX_Camaro
DSX_Camaro's Avatar
They don't melt out. They melt together and can cause extreme damage due to being a complete exhaust blockage. Ceramic cats can break down, metal cannot. There's a couple threads here about SS guys melting high flow cats, and I know sycraft had a supercharged V6 and melted his cats too.
cats, exhaust, supercharger
