Old 04-23-2020, 11:04 PM   #1
beersngars
Drives: 2012 ZL1
JRE Transmission dipstick install problems
Decided to make life a bit easier on myself with the transmission dipstick from JRE. Instead, I added nothing but frustration. This thing fits like crap. I had to tweak, bend, notch and it still doesn't fit worth a damn. Maybe I'm missing something, Others don't seem to have problems.
It just seems to hit the floor pan, bind against the wiring harness and the bracket is so far off, it pulls the tube back out of the grommet if I attempt to force it into place. I doubt I got a bad one since it appears to be an OE part but after 4 hours, I gave up. Any body have similar issues? Any help would be appreciated before this thing ends up in the trash.
beersngars is offline   Reply With Quote
Old 04-24-2020, 12:00 AM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Nope, mine fit like a glove.
Vegas Bound is offline   Reply With Quote
Old 04-24-2020, 06:40 AM   #3
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
I had all the same problems as you, but it does fit. Mine did just take your time. I had a better time taking off the grommet, put it in the transmission first then stab the dip stick in.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 04-24-2020, 06:59 AM   #4
beersngars
Drives: 2012 ZL1
I ended up doing the grommet like you. I also had to loosen the transmission mount to get enough room to tilt the top of the tube up so the angle was right enough to get the tube into the grommet. I see no other option than to cut the bracket off and reweld it.
Old 04-24-2020, 07:19 AM   #5
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
That sounds like a lot of work for what is supposed to be a simple installation. Have you considered the flexible dipstick by Lokar (TD-36L80FM48)?
JB'sZL1 is offline   Reply With Quote
Old 04-24-2020, 09:02 AM   #6
Z/28Dan
Z/28Dan's Avatar
Drives: 2023 1SS 1LE Vivid Orange
Have you called Ted?
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan
Z/28Dan is offline   Reply With Quote
Old 04-24-2020, 10:26 AM   #7
beersngars
Drives: 2012 ZL1
No...pretty much committed to this POS for now.
Old 04-24-2020, 11:10 AM   #8
tartagliazl1
Once i got mine in the right position it bolted right up fine.
Old 04-24-2020, 11:45 AM   #9
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
I found that detaching that harness that runs right there needs to be removed, then mine popped right in with a couple tweaks..
2012 ZL1 preproduction car #13
ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet
JBZL1 is offline   Reply With Quote
Old 04-24-2020, 12:21 PM   #10
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
I saw a video where a guy notched the bracket were the starter cable goes through and makes the installation easier
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 04-24-2020, 01:04 PM   #11
beersngars
Drives: 2012 ZL1
Called JRE. They put me on with a tech that installs them. He gave me a few tips (most of which I already tried) but did make a few suggestions that may help. He did say some go easier than others. LOL...just my luck.
Old 04-24-2020, 02:36 PM   #12
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Well... what tips did he share?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 04-24-2020, 05:54 PM   #13
BLU DUCE
BLU DUCE's Avatar
I have a 2011 1SS/RS Auto and mine was very easy to put in 3 yrs ago. #6L802
Might just be a difference with the ZL1.
Old 04-24-2020, 08:47 PM   #14
beersngars
Drives: 2012 ZL1
Well he mentioned dropping the transmission, putting the grommet in the trans first and then putting the tube in, raising the wiring harness and lubing the tube/grommet all of which I already tried. He also talked about removing the wire retention band completely, removing #8 plug wire and relocating the starter wires.
Bottom line is IT'S DONE. Got home from work tonight, had a couple of beers and went back in the garage with a calm mindset. Laid on the creeper and studied it a bit. Had the wife under the hood holding the upper part while I hand tweaked the bracket and got it stay in the grommet AND got the bracket aligned. It still barley touches the floor pan but I think it will be OK.
The one tip I came up with is, IF you are having the problem with the tube coming back out of the grommet while trying to get the bracket lined up, take a 3' or 4' section of 10 or 12 gauge stranded wire and loop it over top of the tube on the horizonal section, wrap the ends around your hand and keep pulling down with one hand while wrestling the bracket into position with the other. There is simply no where to grab and hold the tube and the wire saved my day.
Thanks for all the help.
