@LS.ACE
Drives: 2014 Chevy Camaro 2SS/1LE Join Date: Jan 2017
How long can I keep the car on jack stands with suspension unloaded
Alright so I have searched and went through all of the posts regarding anything close to this and they were all about winter storage. I just want to make sure I won't damage anything so anyone that could help me with this one I would appreciate it.
I am going to be putting in my Trailing Arm outer bushings as well as my strange s5090s and upgrading to the BMR Xtreme Anti Roll Bar. Due to having my car outside for over a year (a couple months where I live and then it spent a while at the shop) my aftermarket suspension components have a little rust on them. I finally have a garage where I can store her so no need to worry about that anymore. While I have the car in the air I would like to take the parts off and paint them. I would be leaving the car on quick jacks in my garage. How long (if any amount of time) would it be possible to leave the car in the air with the suspension unloaded? Would have to do the painting around the weather. Shouldn't be more than a week but just want to see what the consensus is. Thanks in advance!
Some weird snail with a belt on it
| Tial Q Bov | CCP Jam Cam | Stainless Works 1 7/8" Headers to Custom 3" Exhaust | Alky Control Dual Nozzle| ProMeth Trunk Mount Tank | Melling Oil Pump | DSX Aux Pump | id1050x Injectors | McLeod RXT w/ Monster Billet Release Bearing | ZL1 3.73 Rear Diff | BMR Delrin/Poly Diff Bushings | DSS 1-Piece Aluminum Driveshaft | ZL1 Axles | Metco Driveshaft Loop | BMR Adjustable LCA's, TA's, Toe Rods | BMR Adjustable Sway Bar w/ Fe3 End Links | Mickey Thompson 305/35-20 Street S/S Drag Radials | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
i wouldnt think it should be any problem,as long as you place the jacks correctly.
![]() Drives: 2010 Camaro 2SS Join Date: May 2016
Ok the only things you have to worry about would be the struts/shocks getting rust on the shiny area.Put some lube on them to prevent rusting.
The second thing would be to make sure you have the stands in the correct location and they are stable with the correct or higher weight rating. Other then that I don’t see a problem. |
Banned
Drives: cheby Camaro Join Date: Aug 2019
Just keep on mind you MUST clock the bushings when you are done.
#5 | ||
@LS.ACE
As far as the stands I will be using 5,000 lb quick jacks. Work lovely in my little garage. Appreciate the help That is a definite. But thank you for adding that in there! That is one of the reasons why I had started this project. Wanted to make sure the bushings were clocked and would be installing the outer T/A bushings as well. Definitely one of the most important steps that often gets looked over.
