Old 12-20-2009, 08:24 PM   #1
Stevo
Drives: Camaro 2010 SIM
Inexpensive pedals for heel-toe shifting
After a day at the racetrack it became clear that the stock brake pedal was to high and the accelerator pedal was too far away to easily heel-toe shift.
I got some $20 pedals at PepBoys called 3 A racing that I put on. The stock accelerator pedal is made of plastic so I drilled 3 holes in it and mounted the new pedal that has a nice wide reach toward the brake. I removed the thick rubber pads from the brake and clutch pedal- both made of steel and drilled 3 holes to mount the new pedals. The result was the brake is a good bit closer but still just a bit higher than the accelerator pedal-but good enough to heel toe for me.
Stevo is offline   Reply With Quote
Old 12-21-2009, 12:14 AM   #2
Danny5
Danny5's Avatar
Drives: 10 2SS, 08 Sienna, 12 Sonic
Looks great! What hardware did you use?
It could be that the purpose of your life is to only serve as a warning to others. Ashleigh Brilliant
Danny5 is offline   Reply With Quote
Old 12-21-2009, 08:20 AM   #3
600hp-lpe
Drives: 2010
Momo Pedals are $50.00 and come with mounting hardware.
They have multiple designs and look sexy....
They work Excellent for heel/toe action now that they are installed.
600hp-lpe is offline   Reply With Quote
Old 12-21-2009, 09:36 AM   #4
Looks good
Old 12-21-2009, 02:32 PM   #5
Stevo
[QUOTE][Looks great! What hardware did you use?QUOTE]
Thanks. Came with all the bolts. I added locktight and nylox nuts and cut the bolts so that they do not stick out in back - so as not to catch on my shoelaces.
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
Billet Pedals from Ultimate Pedals Ultimate Pedals Interior Parts & Accessories 33 02-20-2010 11:44 AM
LMPerformance, Spohn Camaro 2010 Tubular Rear Toe Links with Polyurethane Bushings. LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:55 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Toe Links with Spherical Rod Ends. LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:44 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Toe Links with Del-Sphere Pivot Joints LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:39 PM
