Old 04-25-2020, 10:40 PM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
where's PAK connector plug into go?
anyone know where pak connection goes. I have a aftermarket amp. and head unit. I ran RCA jacks from the head unit to to aftermarket amp. and eliminated boston acoustic amp. anyone know where the connector goes. "standard factory" audio connection or "amplified factory" audio connection. Thanks
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 04-26-2020, 08:49 AM   #2
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Should be standard. No amp, you can test this with the radio out. If it does not work just use the other connection. It will not hurt anything.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 04-26-2020, 01:34 PM   #3
lionssfan
lionssfan's Avatar
I purchased a used jl amp that has issues. So just making sure I'm not creating another issue. I plan on purchasing a new amp and want make sure its right.
2010
Edit Signature
