![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Splitters
Anyone know of a ZL1 front splitter extension fit a 1LE splitter?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
I saw those. Not a fan. Looking for matching pieces
No worries, I tried.. Good luck.
![]() ![]() Drives: 2015 Z/22 Join Date: Aug 2015
https://www.aerosportconcepts.com/ has a few extensions; not sure if it's what you're looking for.
#6 |
Instagram: Sangstah
The ZL1 splitter comes to a point in the middle and will look weird with a 1le front lip IMO.
#7 | |
1LE comes to a point also.
#8 |
Instagram: Mr2Hard2See
Drives: 2011 2SS/ RS Join Date: Apr 2018
You would never regret the buy if you did that purchase though. Do you plan to keep the car? I had the same thought about a Anderson carbon diffuser and ikon. My wife and friend said don’t be cheap just buy what you really want and do it once be happy as possible then it’s done right. I’m using aerosportconcepts stuff $$$. If I had went apr I’m sure I would have broke then I would be buying a replacement and the 2 would equal the cost of the 1 I really wanted.
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242 BTR dual springs pushrods lifters retainers etc Che bronze trunnion Ls3 timing/valley cover Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers |
#9 | |
#10 |
You could also buy some Alupanel or similar from a sign-maker and make your own, if you're into that. I bought an ACS splitter which is basically a 1LE replica (or close to it) and am thinking about adding a piece under it, similar to what Kurt (Aero Sport Concepts) did. $150 for a 4x8 sheet. Will also be making my own side skirt extensions, diffuser, wicker bill.
#11 | |
#12 |
Yes ig has some great stuff I’ve seen so I don’t blame ya. Seems like you want to make the purchase soon. I think I had used Black Friday discount on my purchase. Good luck I’m sure it will work out
