![]() Drives: 2014 Camaro 2SS Join Date: Apr 2020
Runs Hot- Replaced EVERYTHING- HELP
Hi Guy- been researching all these threads for 2 days and a lot of great info but still have a problem.
2014 SS. Only 38K miles. Been maintained. Replaced waterpump, thermostat, radiator, radiator cap, temperature sensor and also did Block Test (stayed blue). So she is still running hot ! What am I missing??? Maybe a Flush? Maybe thermostat is faulty? Fans work perfectly fine. Kicked on at 209 degrees. Help please. Last edited by SS-Girl; 04-26-2020 at 09:20 PM. Reason: was confusing |
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
Fans or air bubble coming to mind, maybe toss in a thermostat just because they are cheap and easy to do.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Sounds like you have air in the system.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
How do the hoses feel when running at operational temperature?
#6 |
#7 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
Sounds like air in the system.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
What is the highest temp it is getting to? Before I was tuned (lowered fan temps) and installed the lower temp thermostat, I would get up to 215º in traffic or at lights. I ask because it may be normal if not getting higher than that. I sure does get hot down here.
Glad to see another Spring Hill member in here!
#9 | |
Today idle in driveway for a good 20 min she got up to 232. Took her for a spin around the block, went down for a moment and then creeped back up to 244. I immediately pulled over, turned off and let cool down for a moment. Came back home, stayed at 235. I'm going to replace the thermostat again. Something is telling me it's either that or more air in the system. |
#10 |
USA-1
Have you tried running the car without the radiator cap on?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
#11 |
only when we were getting the air bubbles out.
#12 |
Oh yea, that's definitely not normal.
As mentioned above, it sounds like an air pocket, as you have changed nearly everything. These cars can be notoriously stubborn to get the air out of. To bleed mine I usually let it sit and idle with the radiator cap off and keep topping off each time it lowers, keeping a very close eye on the temp gauge. Once I think I got it, I cap it off, let it idle a bit longer, and then take it out very close to home. I have had it take 30 mins to get everything out.
#13 |
are you filling the reservoir up too?
#14 |
I usually make sure it is at least 1/3-half full. This way it has some to take if it needs it and doesn't overflow if its too much.
| Tags |
| cooling system, overheat, overheating |
