Old 04-27-2020, 03:07 AM   #1
Valdizo
Drives: Zl1
Bk fab supercharger tank
Hi anyone running one of these... do you recommend
Valdizo is offline   Reply With Quote
Old 04-27-2020, 05:11 AM   #2
d kings z28
Drives: 2014 white z28
I have one on the way got it her. https://www.prospeedautosports.com/p...exchanger-tank
d kings z28 is offline   Reply With Quote
Old 04-27-2020, 08:12 AM   #3
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
I like the look of that. That is going to be my next got to have for my car.
Bigtime53 is offline   Reply With Quote
Old 04-27-2020, 10:03 AM   #4
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Prospeed used to be D3. Lots of folks are running the D3 (now Prospeed) tank.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 04-27-2020, 12:32 PM   #5
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Like mine, even though Ted says it's just a Big Heat-sink. I know he is right but still like it because it’s really simple to top the system off and purge any air. Also since I have a lift in the summer I just pull the quick disconnect Pin on the lower HX hose open the D3 and bang quick drain.
I then fill with distilled water and a little water wetter for the summer. The best part is when winter comes for storage I just open the D3 and use a manual hand pump and empty the reservoir to a 5 gallon pail. Then add 100% coolant, start and repeat until my coolant tester gets the -20 degree setting.
ZMEnow is offline   Reply With Quote
Old 04-27-2020, 09:09 PM   #6
SiC ZL1
SiC ZL1's Avatar
Drives: 2012 Blk ZL1 M6
I'm about to order one this week. I'll probably install it and my afco heat exchanger next week. I'll let you know.
2012 BLK ZL1 M6: Rotofab CAI,20in Z28 Reps,5% tint,6K leds/hids,VMaxx TB,JLT CC,BTR Stage2PDSTQ Cam & Valvetrain,Holley VC, AFCO HX,BK Fab HX Tank,MGW Flatstick,Kooks 2in coated headers catless,BMR bushings & arms,160*,2.45 upper,9.06 Lower,ID1050s,Shane Hinds tuned, Pedders Xa Coilovers,DSX Aux pump & Flex Fuel,Corsa.
SiC ZL1 is offline   Reply With Quote
Old 05-11-2020, 02:21 PM   #7
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
I have the D3 tank. Makes filling it up easy as can be.
owhite3003 is offline   Reply With Quote
Old 05-12-2020, 10:07 PM   #8
SiC ZL1
SiC ZL1's Avatar
So I received my BK Fab intercooler reservoir yesterday and I'm very pleased with it. Its a nice aluminum reservoir. Its similar to old lingenfelter/rotofab ones. Just its not plastic. Comes with push lock connectors as well. I believe there is just one guy that actually makes these out of Missouri. I'm all for supporting a small business. They are 60-$70 cheaper than prospeed tanks. I like where it mounts better too. Looks like it'll easily hold a half gallon or more of coolant. I'll install it with my afco intercooler in the next few weeks.
Old 05-23-2020, 03:10 AM   #9
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Have any pictures installed? That looks nice and my Rotofab leaks at the cap
FasNuf is offline   Reply With Quote
Old 05-24-2020, 04:59 PM   #10
SiC ZL1
SiC ZL1's Avatar
Not yet. I was going to do it this memorial day weekend, but the fan on my central air unit took a crap. So maybe next weekend.
Old 05-24-2020, 05:03 PM   #11
SiC ZL1
SiC ZL1's Avatar
Here's 2 pic to give you a general idea.
