Old 04-27-2020, 10:00 PM   #1
GoodGuy_Anthony
Drives: 2013 Camaro SS 1LE
Brake/Clutch Fluid Reservoir
To start off, I got my 2013 1LE about 3 years ago used. Since about a year into owning it, I noticed some brake fluid around the plastic reservoir. I changed the cap thinking there was a faulty seal on the cap. Continued to drive thinking it was fine but it continued to leak, this time around the middle area where the reservoir container seams together (essentially the lip near the halfway mark).
I bought another reservoir to replace it but I was curious if this was a common occurrence or what.
GoodGuy_Anthony is offline   Reply With Quote
Old 04-27-2020, 10:45 PM   #2
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Known problem '10-14's that dealer will fix. See post 29 in this thread
https://www.camaro5.com/forums/showt...ir+leak&page=3
camguynj is offline   Reply With Quote
Old 04-28-2020, 10:25 PM   #3
mikeman
Banned
Drives: 2015 Camaro
Never heard of it leaking at the molded seam, just the cap. I'd just replace the reservoir and be done with it. Cheap plastic.
mikeman is offline   Reply With Quote
2013 camaro 1le, 5th gen, ls3, maintenance
