Old 04-29-2020, 12:31 PM   #1
flynbiya
Drives: Ford Raptor
Wheels on Backwards
I was standing in a parking lot this am and noticed the front offset looked off, and the rear looked equally off in the opposite direction. Looking at the hub, it sure looks like the previous owners tire shop installed them backwards thinking that they were the same due to running a square tire setup.
I guess I know what I get to do tomorrow!!
Anyone else run into this?
flynbiya is offline   Reply With Quote
Old 04-29-2020, 12:35 PM   #2
Shoupaloop
Drives: 2015 Z28
There's a peg/prong to prevent this from happening.
Shoupaloop is offline   Reply With Quote
Old 04-29-2020, 12:38 PM   #3
flynbiya
Drives: Ford Raptor
Could it still be done? Wondering now if they are correct then? Do the fronts bulge slightly and the rears sunk in a bit?
Gen2 Raptor // Z28 // Ferrari 360
Old 04-29-2020, 01:10 PM   #4
ariZona28
Give speed a chance
ariZona28's Avatar
Pull one off. Part #s are stamped on wheel. Reference "sticky" for Z/28 part #s (above in this forum). 225 are 11" fronts. 227 are 11.5" rears. Be careful removing these wheels, easy to scratch and care needs to be taken not to harm rotors. When you said "backwards" I was thinking something much more entertaining.
ariZona28 is offline   Reply With Quote
Old 04-29-2020, 01:13 PM   #5
flynbiya
Drives: Ford Raptor
Originally Posted by ariZona28 View Post
Pull one off. Part #s are stamped on wheel. Reference "sticky" for Z/28 part #s (above in this forum). 225 are 11" fronts. 227 are 11.5" rears. When you said "backwards" I was thinking something much more entertaining.
haha! Thanks. Car is getting some audio upgrades at the moment but I will get it on the lift when it gets back home.
Old 04-29-2020, 01:17 PM   #6
j o n
j o n's Avatar
Drives: 2015 Z/28 #0058
IDK if it's possible to get the rears on the fronts.. the rears are 32.25mm offset and fronts are 11mm... pretty sure it would be contacting the front strut
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's
- '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony
Sold:
- '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's
https://www.instagram.com/__jon__athan__/
j o n is offline   Reply With Quote
Old 04-29-2020, 01:21 PM   #7
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Rears cannot go on the front.
Looking at the car, the fronts are wider than the car itself, even with the wheel arches. Where as the rears have a very slight tuck. This can be over pronounced when wider tires are on the rims.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook.
Follow: @5th_gen_z28_registry
I track wrecked Z/28s Total lost -41
Zslash28 is offline   Reply With Quote
Old 04-29-2020, 01:26 PM   #8
ariZona28
Give speed a chance
ariZona28's Avatar
Since you're new to the Z/28 world do yourself a favor and go through past threads to learn about some of the odd maintenance issues with this beast. I threw in an edit above about the wheel removal. No wheel cleaners/tire dressing near rotors, watch out for drivers side seatbelt scuffing, steering wheel and shift nob cleaning etc. I'm still in the learning stage myself.
Old 04-29-2020, 01:30 PM   #9
j o n
j o n's Avatar
Here's a nice thread with reference of the clearances if rears were on front... spacers would be needed for sure
https://www.camaro5.com/forums/showt...t=square+setup
Current:
Sold:
Old 04-29-2020, 01:33 PM   #10
flynbiya
Drives: Ford Raptor
Well that solves that then. Thanks for the confirmation!
Old 04-29-2020, 05:28 PM   #11
pzero
pzero's Avatar
Drives: 2015 Camaro Z/28 #968 Silver Ice M
Man, sorry to hear that. Yes, it's do able. One of the shop here did the same thing to mine. Installed front to rear vice versa. Tires are all the same but the rims are 7.5x11 front and 7.5x11.5 rear. Check the rims and make sure they are not scratched. 11.5 on the front will tear up the multi-link strut from rubbing. Good luck.
FYI: Shop name withheld because they ate the cost and fixed it all or I was going to rip a new hole with a law suite.
pzero is offline   Reply With Quote
Old 04-29-2020, 07:50 PM   #12
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
On my car the front wheels had yellow paint under the center caps for the two from wheels.
69L48Z27 is offline   Reply With Quote
Old 04-30-2020, 12:23 AM   #13
Tankslapper
Drives: Z28
This is correct, pull the center cap, yellow ring goes on the front. I don’t think you can fit the fronts on the rear without destroying brakes...
Tankslapper is offline   Reply With Quote
Old 04-30-2020, 11:51 AM   #14
flynbiya
Drives: Ford Raptor
I haven't had a chance to pull a wheel, but I am driving the wheels off of this car and nothing is rubbing, etc. so I assume its just the way they fit.
