Old 04-30-2020, 04:11 PM   #1
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I think I finally got the right combo... dyno results inside !
This winter I picked up a set of FED stage 2 heads, and had a cam ground by TSP to suit my needs. Went with Cometic .040 head gaskets and Johnson 2116lsr tie bar lifters. Had to use 4 different length pushrods to get the preload in spec. Needless to say, I'm a happy camper!!!
Also, once on the dyno, my tuner sensed that she was thirsty for more air. Picked up 16 hp with this 5 inch intake.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 04-30-2020, 04:30 PM   #2
Roader
Drives: Camaro
Dang that curve stays right at 600 for a while if you can push it out more
Roader is offline   Reply With Quote
Old 04-30-2020, 04:37 PM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
600 rwhp, that is freaking awesome
You nailed the combination man, that thing has to fly.
The intake tube looks bad ass too! Love the all Orange motor, reminds of the SBC/BBC days.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 04-30-2020, 06:13 PM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Nice!!
More to come.
Black_SS10 is offline   Reply With Quote
Old 04-30-2020, 06:50 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Holy crap Clark,that's freakin awesome! You nailed that one !! Must be a ton of fun to drive too.. Enjoy it.
Old 04-30-2020, 06:56 PM   #6
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Hell yeah clark! That’s a killer combo there. X1 loves cubes and rpm along with compression
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 04-30-2020, 07:11 PM   #7
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Wow !! Awesome numbers and combo! 600rwhp with ls3 heads and hyd cam on a 416! Love it!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 04-30-2020, 07:36 PM   #8
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Awesome
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 04-30-2020, 08:27 PM   #9
Clarkstar
Clarkstar's Avatar
Fyi... Late Model Throttle has a facebook page, they posted a cool pic and idle clip...
Old 04-30-2020, 09:41 PM   #10
zz430camaro
Drives: 2015 1LE
Sounds ****ing sweet!
Old 05-01-2020, 08:51 AM   #11
xc_SS/RS
Drives: 2010 Camaro SS/RS
damn 5” intake ftw! Awesome results!
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-02-2020, 04:39 AM   #12
Bo White
Bo White's Avatar
Awesome you did a test on the bigger intake tube. I was planning on testing that on my build.
Old 05-02-2020, 08:07 AM   #13
aaannntt1965
aaannntt1965's Avatar
Drives: 2010
Good Job Man.
aaannntt1965 is offline   Reply With Quote
Old 05-02-2020, 09:47 AM   #14
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Very nice Clark!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
