Old 05-01-2020, 09:21 PM   #1
Renzee
Drives: 2011 Chevy Camaro SS
2011 No Crank/No Start
2011 SS. Drove to the convenience store car was running normal.* Came out, started fine and as I drove to exit, car stalled out.* After a few attempts to try and restart, the car would crank and turn over, then die immediately.
Had it towed home.* Tried to start it a couple of times in the driveway and it cranked and turned over then immediately died.* Then the battery was basically dead.
Next day, charged the battery, checked the codes and it was throwing a P069E (FPCM has detected a problem) and P1682 (ignition switch circuit 2).* Now, when I turn the key, everything comes on as expected, dashboard lights, gauges, etc.. But when I turn to start I get nothing, no crank... just nothing.* So, at this point, I assume it is the ignition switch.* Checked all fuses and all are good (visibly, not with multimeter.. yet).
Replaced the ignition switch... still no crank.. nothing.
Any Other ideas?????
I'm going to meter test all wires/fuses next.
Renzee is offline   Reply With Quote
Old 05-02-2020, 06:22 AM   #2
redcoats1976
how about a known good battery first?these car do weird stuff when the battery goes bad.
Old 05-02-2020, 03:56 PM   #3
Sparko
Sparko's Avatar
Drives: 2010 Camaro 2SS
I second the checking of the battery. It doesn't take squat for amps to run all the lights and correct volts doesn't always mean good battery. Once you apply a heavy load it will tank which is why battery load testers exist. Pretty much any auto parts store has a load tester, bring it in a see what happens.
2010 Camaro 2SS
2018 Charger GT+
2005 Cavailer LS S/C - Sold
'87 HD FXRT - Wrecked pending repair
Sparko is offline   Reply With Quote
Old 05-03-2020, 09:01 AM   #4
Renzee
Sorry.. meant to mention that I did swap with a good battery first thing and still nothing.
So.. the mystery continues. Meter tested all fuses, all are good. tested that the fuse block is getting power. Swapped Starter relay with similar A/C relay still nothing. Swapped Run/Crank relay with similar relay... nothing. Dropped starter and meter tested solenoid wire... No power to wire when ignition turned..
OK, so now we're getting somewhere... But where????? new ignition switch so it can't be that (unless some asswipe returned his bad one to the store). Not likely the relay, would be strange if both were blown at the same time. Maybe fuse block issue? maybe frayed wire from fuse block to solenoid? Dare I say it.. Maybe the ECM? Or, I am currently looking into bypassing the neutral safety switch (although I think it is in the tranny, so that may be a dead end); however, trying to start in neutral does not work so I don't think it is the neutral switch)
Old 05-03-2020, 09:22 AM   #5
christianchevell
old school chevy rodder
christianchevell's Avatar
You did not state if your a L99 automatic or manual..the automatics can do things when the neutral safety switch is off under the shifter BTW..... And our starter is stock a Mini starter so it struggles real bad if built with heat also BTW.. Just a couple thoughts the first one may apply...Good Luck!
Old 05-03-2020, 10:06 AM   #6
Renzee
thanks. It is an automatic
Old 05-03-2020, 10:45 AM   #7
CamaroBarb
Banned
Drives: cheby Camaro
Swap the relay with another one.
CamaroBarb is offline   Reply With Quote
Old 05-03-2020, 10:47 AM   #8
redcoats1976
not familiar with the safety switch on these cars but if it plugs into the wiring harness you could unplug the plug and bypass it with a piece of wire.at least you could find out if thats the problem.
Old 05-06-2020, 08:17 AM   #9
Renzee
Thanks for all your replies.
I broke down and had to tow it to the dealer. Ended up being a corroded wire.
Old 12-09-2021, 07:56 PM   #10
bilydean
bilydean's Avatar
Drives: One of the rare ABM camaros
I know this is old, but would you know exactly which/what wire was corroded? My son has the exact same issue in his 2011 camaro.
2000 5/23
3000 5/27
3400 6/20 TPW of 6/29
3800 7/3
4D00 7/8 interned at QC
4B00 7/16 Released from QC
4200 7/20
8/5 We picked up the car
bilydean is offline   Reply With Quote
2011, camaro, ignition switch
