![]() Drives: 77 z28 Join Date: Mar 2017
New member to the "(*&^%$@#@!+) blend door club!
Another FL boy here that is being inducted into in blend door club.
Had an on the spot legal cruise and car show on one of our first 91 degrees hot days, and warm air on drivers side, not hot but way warmer then the passenger side ___T!Been watching "InFiD3ViL" so my first step will be block off the heater hoses till Oct. or Nov. In the mean time one of my closest friends is a fabricator and also gear head going to get with him about making a replacement door out of,,,hmmm real carbon fiber, aluminum, stainless, he is a master so I'll see what he recommends. Any one got a broke one with both pieces we could use for a mock up? Wayne |
![]() ![]() ![]() ![]() Drives: 2011ss/rs camaro Join Date: Sep 2011
Good luck with the repair..What causes it to break?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert Join Date: Sep 2019
Chinese blend door relays. I think they use the same ones that Ford uses in the Mustang. Not trying to make a joke - I had an 09 GT for a couple years and the one thing that I had to replace consistently was the blend door relays. But at least they were a lot easier to get to on the Mustang.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Just make sure to use a loopback hose on the water pump and not just pinch them off. I only pinched them for testing and temps shot up super quick. I'm sure you knew that, but just in case.
Damn, a real carbon fiber one would be great. Or one that was somehow reinforced with steel. The OEM doors look to be a fiberglass reinforced plastic, but they are just too brittle in the hinge area. If you come up with any amazing ideas please share them! Good luck! It's getting hot as balls down here now. This is such BS! I hate to say it, but I honestly believe that every Camaro will eventually suffer from this. GM seriously dropped the ball on this one. BTW, I got my blend door on Rockauto.com. It was like $20 with shipping/tax.
#5 | |
Copy that on the water pump.
If he can come up with a fabricated door that works it would make it one time fix, I hope. It will no doubt be more expensive but knowing this guy he will not stick it to us. I'll be seeing him this week so first I'll show him a Pic to see what he says. BTW, is this both the 5th gen and 6th gen Camaros ? Quote:
#6 | |
![]() Drives: 2021 Camaro SS Convertible Join Date: Apr 2016
2015 SS2/RS, SCT Tune (Dynosteve), Vitesse Throttle Controller, Vararam VR-DRX CAI, Vararam Power Wedge TBS, Granatelli Performance MAF |
#7 | |
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
This '12 is my last new GM and I've always been a Chevy guy. To be fair though most brands are now building engineered failure into the vehicles to get you to trade in for a new one and they are all going DI.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
#8 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Make it out of cast iron, a forged steel jack-screw and a steel crank handle. All made in the US of A!!!
#9 |
That would be amazing! Everytime you turn the AC temp down it would sound like someone sealing a bulkhead door on a battleship.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
from what i understand bypassing the heater "fixes" this?living in florida that would be my first step,ive used the heater twice in 5 years.
#11 |
Give speed a chance
If you haven't found the thread yet check out Heater Blend Door Hack (currently on pg 7 but soon to be on pg 8). Plenty of entertaining info jam packed into over 100 posts. This should be required reading for Gen 5 owners with a quiz at the end and a certificate to put on your refrigerator.
#12 |
![]() Drives: 2013 1LS Join Date: Apr 2019
Not 100% sure but I heard that the actuator's range of motion breaks the plastic when it moves too far so don't put the dial all the way to the right or left.
#13 |
#14 | |
![]() Drives: 2013 Summit White 2SS/1LE Join Date: Jul 2018
For everyone who is in a relatively warm part of the country in Winter, the heater bypass is obviously the quickest, cheapest solution. I cut off the hoses just outside the firewall and plugged in a U-shaped fitting to circulate the water. So far, so good, with no leaks and no overheating. As a side benefit, with this bypass setup, when it's hot outside, the AC will blow even cooler since it is now completely isolated from the hot coolant that normally flows through the HVAC box. I also found out years ago that AC works great for defrosting windows. Again, this is only a good "find" for those of us fortunate enough to live in mild weather areas. |
