Old 05-05-2020, 06:12 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
What else do I need?
Found another option for my clutch replacement. What else do I need? Flywheel? Slave? Will this bolt directly to the stock flywheel, or would I need to purchase 1?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 05-05-2020, 06:36 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
You definitely want a new slave cylinder with the billet bearing support and remote bleeder.
Sent from my Pixel XL using Tapatalk
Old 05-06-2020, 11:00 AM   #3
RupertPupkin
Thanks Larry.
730whp: 630Trq
