![]() Drives: 2013 Camaro LFX 2LT Join Date: Mar 2020
Engine Operating Temp
Asking to educate myself... No overheating issues.
What is the normal operating temperature for an LFX engine? I've had the car for about 5 months now and I've looked here and there but I can't find a straight answer as to what the operating temp should be? Also, how does that temperature translate to visuals? I mean how does that look in the gauge? Straight in the middle or leaning towards left or right? Thanks! |
![]() ![]() ![]() ![]() Drives: 15 Camaro SS Join Date: Oct 2018
Straight in the middle of a factory 5th gen seems about where the factory setup rides. Mishimoto rad and 170 thermo and its far left of center on my build
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
Banned
Drives: 2015 Camaro Join Date: Aug 2018
I'd go by the digital readout in the DIC.
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
These are my displays on my '15 2LS LFX V6 auto trans, all stock no mods. Ran for approx 20 min, 70 mph with A/C on. Coolant temp gauge on speedo approximately 1/3 position. DIC display 185 degrees F. Oil temp 198 degrees F. Ambient temp was 92 degrees F. These are what I consider "normal" op temps. I have seen oil temps get up to about 210 or so in the middle of summer but nothing alarmingly excessive.
![]() Drives: 2013 1LS Join Date: Apr 2019
I've always noticed the temp gauge needle is in the middle between the center line and the small line on the cold side. Don't know the actual number but as long as it's between 195 and 220 then you're good.
#6 |
![]() Drives: 2014 Camaro 1LT Join Date: Aug 2019
I have a 2014 V6 auto (LFX), and my gauge and temps are almost identical to Arizona's. I don't monitor the numeric readout all that often, but I do notice that the needle on my gauge hardly ever (if ever) has exceeded the halfway point between the quarter line and the halfway line.
I don't check my coolant level as much, either, due to the engine never getting too hot. Maybe once a month I guess? As long as my block temp is being regulated, what do I care. |
#7 |
Mine averages 192-210
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
#8 |
Banned
The V6 seems to run cooler for some reason.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
I wish the early cars had a DIC like Arizona's car. We get coolant temp on one screen right in the middle, no bars or anything. Also, no oil temp or pressure on the DIC.
#10 |
#11 |
Banned
#12 |
Thanks everyone! First time owner here, wanted to check what your avg temps are.
My ‘13 LFX agrees with y’all, somewhere in the middle between the cool quarter and the center line. |
