Old 05-08-2020, 11:38 AM   #1
Camarobychance
Drives: 2014 AGM 2SS RS 1LE
SUSPENSION HELP PLEASE!!!
I just recently purchased Koni orange shocks with eibach springs. Upon installation everything was going perfectly fine until I got to the back left (the last one). I got everything hand tight (no tools) and went to to align the knuckle with the lower control arm and i can’t get it aligned for the life of me. I have zero idea what would be causing this as the back right was just fine. PLEASE HELP IM STUCK IN THE MIDDLE OF THIS PROJECT WITH 1 BOLT TO GO!!!
Camarobychance is offline   Reply With Quote
Old 05-08-2020, 11:44 AM   #2
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Do you have the sway bar disconnected?
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 05-08-2020, 11:47 AM   #3
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
Are all the other bolts tightened down yet? If everything is torqued, you're going to have to loosen it all up and then it should help you get things lined up. I usually wait to torque everything until all the bolts are in just because of this.
Also, you're going to want to have the suspension at ride height when you do torque things so bushings aren't pre-loaded. Have you seen the thread about timing bushings?
Sent from my Pixel 4 XL using Tapatalk
terry_b is offline   Reply With Quote
Old 05-08-2020, 11:54 AM   #4
Camarobychance
Sway bar is disconnected and all bolts are loose. I actually just took the whole strut assembly out and I still can’t get it to line up. I’m so confused and frustrated
Old 05-08-2020, 12:05 PM   #5
Camarobychance
Yes I have seen the threads on timing bushings
Old 05-08-2020, 12:08 PM   #6
terry_b
terry_b's Avatar
Take a couple other bolts out and try in a different order. Something is binding up or limiting the movement of the knuckle enough that it won't line up.
Old 05-08-2020, 12:09 PM   #7
Camarobychance
What bolts do you suggest I remove?
Old 05-08-2020, 12:18 PM   #8
terry_b
terry_b's Avatar
Probably the trailing arm and the toe rod, then there should be plenty of movement
Old 05-08-2020, 01:16 PM   #9
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
Pull the hub out at the bottom (grabbing the rotor), while holding it bring the lower control arm up
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 05-08-2020, 08:47 PM   #10
terry_b
terry_b's Avatar
Did you get it together?
help me, please help, suspension
